wanting to install a set of lights - Kawasaki Versys Forum
post #1 of 11 (permalink) Old 01-30-2013, 10:35 PM Thread Starter
Que
Que's Avatar
I've been wanting to install a set of halogen lights on my V for a while now as I do a lot of night driving. I don't know if installing a set of halogen lights will be bad for the battery. I have read a lot of people install LED's...which are nice but a bit to rich for my blood in way of price. My question is, would I need to do something extra to make sure they they work correctly ?
Que is offline
post #2 of 11 (permalink) Old 01-30-2013, 10:51 PM
A set of Halogen won,t hurt your battery and just get the wiring done properly with a relay.
post #3 of 11 (permalink) Old 01-30-2013, 11:04 PM
You have halogen lights already or do you mean extra lights as in spotlights?
post #4 of 11 (permalink) Old 01-30-2013, 11:13 PM
Is this what your want to install.
post #5 of 11 (permalink) Old 01-31-2013, 12:46 AM Thread Starter
Que
Que's Avatar
that's it. Being I don't have much moola I grabed a set from wally world for 20 bucks. I need to find some place to put them along with a set of cheap brackets. When a "relay" is needed is that just a seperate on and off switch? any way what you have, that's my goal\.
Que is offline
post #6 of 11 (permalink) Old 01-31-2013, 04:09 AM
andrewhtf's Avatar
Wiring up a pair of lights has been discussed elsewhere in the forum, time to dig back some old threads, but basically it's the same for both halogen and led type of lights.
Pull a wire from battery direct to a relay, make sure you have a 15A fuse along the line, and then from relay 2 lines goes to each of the light's positive lead. An on/off switch is optional but preferred. Use at least 14 gauge wire but 12 would be better. Remember to ground the lights.
Then tap a wire from the ignition or the headlamp positive lead to the relay's switching lead. Ground the other lead. You may use a 20gauge wire. Zip tie everything and re-assemble your plastics, put the key into ignition, fire the bike up. Your lights should come alive together with the headlamp or if a switch is installed, flick it on.
Current : Maroon 2011.
Up next :
andrewhtf is offline
post #7 of 11 (permalink) Old 01-31-2013, 04:28 AM
andrewhtf's Avatar
For mounting of lights if you have an engine guard, you may use some bar clamps.
Alternatively some members here uses longer bolts and spacer tubes and mount it on fairing mounting holes.
Up next :
post #8 of 11 (permalink) Old 01-31-2013, 06:13 AM
Lights
$20.00 lights from Wal mart, spacer and longer bolt from Home depot.
Cb
ID:	16692   Click image for larger version
cb1313 is offline
post #9 of 11 (permalink) Old 01-31-2013, 10:30 AM
Banned
Look into <Motorcycle Cree LED>
overseas suppliers are much cheaper
Seeya is offline
post #10 of 11 (permalink) Old 02-13-2013, 03:18 PM
I recently bought two Acerbis Cyclone front masks, with a total of 2 hi beams and 2 fog lights. I mounted to fog lights to the Versys:
Decent light and visibility!
The hi beams were for my other motorcycle.
total cost €80 in a clearance sale.
2008 Kawasaki Versys
1994 Honda NTV 650
1999 Suzuki AN125
blahwas is offline
post #11 of 11 (permalink) Old 02-17-2013, 06:58 PM
recently did a cannibalized install of PIAA 004xt's on mine. Had a set that I took off my pickup, needed a new lens/bulb for the one. Used a spare PIAA wiring harness, lots of cutting. Mounted the relay under the fairing, took fused power from my fuze block under the seat and a hot power from the battery. Mounted to my engine guard, still have some angling and other minor work to do, once the weather turns a little nicer.
'09 Candy Plasma Blue Versys 650 (the fastest color)
Givi DS 450 Windshield
SW motech engine guards
HT Teton Panniers
Acerbis handguards
Avon Distanzia tires
Garmin Zumo 665
dual power usb/12v plug
Givi trunk on custom mount
colodak is offline
