Bulbs for Versys 2010 - Kawasaki Versys Forum
post #1 of 21 (permalink) Old 01-27-2013, 10:32 AM Thread Starter
Hello,
i'm looking for the exact type of bulb for High and Low and the small one above them, and the License Plate Light.
i'd like to buy led or Xenon instead of them.
BTW the model is 2010.
Thanks.
mendilevin is offline
post #2 of 21 (permalink) Old 01-27-2013, 02:52 PM
I would avoid replacing your flasher bulbs with LED's as they require a solid state flasher to function plus are only on when turning.
Other running lights can be replaced with LED's, just check EBay or http://www.superbrightleds.com/ - they make direct screw in replacement bulbs for most common bulb sizes.
You cannot directly replace your headlight bulbs with LEDs though as they will not be bright enough. For your low beam you can buy a H7 size HID replacement kit that comes with the bulb and power transformer XENON requires for about $30-40. The high beam bulb, which is also an H7, does not work so well with HID because a draw back of florescent bulbs like HID is they take 30 seconds or so to reach full brightness. Also the long tubular shape of hid bulbs does not focus the light correctly in a reflector unit designed for a shorter incandescent bulb. This is more pronounced with the high beam.
Do not confuse white haligon bulbs for XEXON bulbs - they sometimes mislabel white bulbs as XENON bulbs. Real XENON or HID bulbs are florescent and require a transformer and ballast to work.
post #3 of 21 (permalink) Old 01-27-2013, 04:27 PM Thread Starter
Thanks for the answer.
HID Kit is unlawful in my country, so i just like brighter light.
what about OSRAM NIGHT BREAKER ?
BTW what is the type of bulbs? High and Low and the small one above them, and the License Plate Light ?
post #4 of 21 (permalink) Old 01-27-2013, 05:24 PM
This is in another thread, what I and many others run, can't remember the lumens, think it is 2100 as opposed to OEM 1500. Several people have purchased from eBay, offer around $6 per lamp----
http://www.ebay.com/itm/200704833717...84.m1438.l2649
Also link to one of many posts on this---- and my housing has some heat damage, a bit blue, but that is after four years.
http://www.kawasakiversys.com/forums...=night+breaker
post #5 of 21 (permalink) Old 01-27-2013, 05:33 PM
I use the Osram Night Breakers. Very happy with them.....http://www.motivemods.com/OSRAM-Nigh...osr-nbp-h7.htm
post #6 of 21 (permalink) Old 01-27-2013, 05:56 PM
Headlight high and low beams are H7's and city light and license plate are T10 wedge bulbs.
post #7 of 21 (permalink) Old 01-29-2013, 01:04 AM
andrewhtf's Avatar
As stated by maverick above.
I tried nightbreakers before. I would say the improvements to be hardly noticeably. Sure, slightly whiter lights compared to the yellowish stock but brighter and shines further as advertised? Well, not to my eyes. Plus the bulb is short on life, i think mine on the low beam lasted about 300+ hours only. Popped back the stock halogen instead.
I'm not expecting much on its competitions too, phillips silverstars and sylvannia, Also decided against HID xenon kit as it would not be good in night mists and rain, something that regularly happens in the place i ride. so i took the route of going LED spotlight. I would be putting a 65 watt halogen in place of the high beam as and when the burnt off too.
Current : Maroon 2011.
Up next :
andrewhtf is offline
post #8 of 21 (permalink) Old 01-29-2013, 06:20 AM
Zatx's Avatar
Ummm... LEDs work fine in the turn signal lights. They certainly flash anyway. They actually flash faster than the stock bulbs apparently due to less resistance.
I have LED's in my turn signals, license plate light, and driving light with no issues.
Zatx is offline
post #9 of 21 (permalink) Old 01-29-2013, 07:07 PM
Hi,
Sorry if this is a thread drift (couldn't find much using the search function) but i've gone through a few headlight bulbs lately. The last one to blow completely smashed the globe to pieces ie just 'glass dust' in the headlight housing instead of shattered bits of glass! The time before the low beams stopped working then a day later the high beam failed too. I replaced both bulbs and they still didn't work so i checked the fuse and found it had failed. New fuse and it was right as rain til the other day when the above happened.
I've got her booked in tomorrow to have it looked at but does anybody have any guesses what is wrong? Regulator on its way out? I haven't got a multimeter so i can't check any current draw etc (i guess i could just go and buy a multimeter!) but everything else on the bike is perfect. The battery is probably original (2008) but i've had it on the charger a few times during down time to keep it topped up. Starts with a flick of the starter, no dimming of lights before they fail, no change in indicator flash rate.
It looks like the electrical components of the versys are relatively expensive according to ebay so hopefully its not too painful!
Thanks in advance!
JB
Its the Pleats is offline
post #10 of 21 (permalink) Old 01-30-2013, 05:14 PM
I too.
That is correct, as you had the wrong bulb, go to the link I provided and scroll down to Invaders post,
lumens is 1750.
http://www.kawasakiversys.com/forums...9&postcount=10
The other link on ebay is the same bulb as the H7 hyper, 2100 lumens. Here is a comparison on a VW car.
http://www.my-gti.com/1780/upgrading...d-65watt-bulbs
I do a lot less night riding but I can say with high beam on, I have a total of 4200 lumens as compared to stock of 3000 lumens--------same 500 hour lamp life, and it is a big difference over stock.
post #11 of 21 (permalink) Old 01-30-2013, 05:26 PM
Originally Posted by Its the Pleats View Post
Hi,
Thanks in advance!
JB
Well my guess is other than regulator problems, much of the electronics on the bike is very unforgiving when it comes to overvoltage. One guess is that the bulbs have been touched by human hands before install, this will cause failure. If you accidently touch glass, use isopropyl alcohol .
post #12 of 21 (permalink) Old 01-30-2013, 09:09 PM
I thought about the idea that i touched the bulb when installing it but i always wore cotton gloves and am careful about not touching them. Since three bulbs have blown i can probably rule that out. The v is at the shop now so hopefully i get a call saying they found whats wrong and its a cheap fix. The more likely outcome is that they find nothing wrong, charge me an hours labour and a new bulb and that will blow in the next few weeks! I really hate electrical problems on bikes. Unless there is smoke pouring out of a component its alway hard to replicate the fault.
Fingers crossed!
Sent from Motorcycle.com App
post #13 of 21 (permalink) Old 01-30-2013, 09:39 PM
Just got off the phone to the mechanics and they reckon the bike is putting out 14.9V at the headlight! They've moved into their second hour of labour and and madly going through wiring diagrams trying to find which wire could be causing a bad earth or similar.
So maybe no parts required, phew!
post #14 of 21 (permalink) Old 01-30-2013, 10:22 PM
I can't see 0.7 VDC causing a problem, normal running voltage is 14.2 VDC. What I would suggest is you may have a battery problem, like a loose connection at the terminal. All drawings use both the wire connection to minus plus the frame ground, so no chance of losing ground. Also, a bad ground doesn't give over voltage, typically low voltage. The car with one dim headlight, is a bad ground. The other possability is the headlight relay is due to be replaced, a sparking relay contact will cause bulb failure. If you ever noticed someone turning on a incandescent light in a room that shared the same circuit with a existing light already on, you would notice a momentary dimming of the light that was already on. That is in rush current that causes that, the filament is low resistance and until it heats up the current could be 6 times its normal current ( we are talking a second).
post #15 of 21 (permalink) Old 01-30-2013, 10:59 PM
Thanks wizard. Now they're telling me they've traced it back to a fault in the voltage rectifier. $240!! Anybody got a link to a cheaper one?!? I'll have a search...
post #16 of 21 (permalink) Old 01-30-2013, 11:06 PM
Not positive but should work on a 2010.....http://www.ebay.com/itm/RICKS-VOLTAG...20913523286%26
post #17 of 21 (permalink) Old 01-30-2013, 11:10 PM
andrewhtf's Avatar
lumens is 1750.
Yup, i do have that bulb next up on my list. My only concern is the extra 15w will surely generate more heat for the housing and load stress for the stock wiring hence only intends for it to be the high beam bulb. For the low beam, i find it to be sufficient to use stock bulb as it would be supplemented by my side spotlights when necessary.
Even with the stock bulb, the low beam housing already have "burn" marks on the reflector above the bulb.
Up next :
post #18 of 21 (permalink) Old 01-31-2013, 05:34 AM
both new and used , several have purchased stators from them, look under burnt stators, even new from them is less than half. http://www.rmstator.com/en/catalog-y...ys?filter=true
post #19 of 21 (permalink) Old 01-31-2013, 05:36 AM
only 10 watts more, and my reflector went blue several years ago, still works fine,
post #20 of 21 (permalink) Old 02-02-2013, 02:09 PM
I had another look, Australia would be very expensive to ship from Quebec, I would inquire though, may be woth your time.
