Why am I only getting 3.5v on the accessory circuit? - Kawasaki Versys Forum
Like Tree4Likes
  • 1 Post By onewizard
  • 2 Post By leftbrain99
  • 1 Post By fasteddiecopeman
post #1 of 5 (permalink) Old 03-10-2019, 12:23 PM Thread Starter
Troubleshooting now but I thought I read something similar to this recently here and I just can't find it now. I have my Fluke on the accessory connector and I'm reading 3.5v. Same reading on the accessory fuse. Bike starts fine, same readings.
leftbrain99 is offline
post #2 of 5 (permalink) Old 03-10-2019, 12:27 PM
Meter Setting??
You wouldn't be on volts AC would you? Have you used your meter to measure current recently and forgot to switch the position of the leads, blew a fuse in the meter? How are you measuring the reading on the accessory fuse, with the relay disconnected and the positive pin to ground?
onewizard is online now
post #3 of 5 (permalink) Old 03-10-2019, 12:30 PM
Colour Code Relay wiring 2015
HoosierFordMan likes this.
post #4 of 5 (permalink) Old 03-10-2019, 10:12 PM Thread Starter
Ehhhhh, I've owned this meter almost 25 years and I've never noticed it has a low battery indicator. And it's on right now, which is why the readings are off. I usually kill the battery by leaving it on I guess so I've never seen it in low battery mode. And I swear I checked the voltage at the bike's battery terminals earlier, but I guess not, or not correctly. It's reading low everywhere. So.... ummmm.... carry on now - nothing to see here - just looking for a 9 volt battery for the Fluke, now
onewizard and HoosierFordMan like this.
post #5 of 5 (permalink) Old 03-11-2019, 03:05 PM
... - just looking for a 9 volt battery for the Fluke, now
If you're coming by HERE - I'll give you one...!
leftbrain99 likes this.
Similar Threads
12v/5v plug, the cheap way! AdventureSeeker Modifications - Cosmetic - V-650 5 05-28-2016 06:18 AM
Why don't motorcycles have accessory power outlets? RockyMoto General Discussions - V-650 32 05-02-2011 11:36 AM
Am I the only one with this problem... Element Verticalscope Forum Support / Help (Kawasakiversys.com) 8 03-01-2010 12:10 PM
Versys electrical system: 5V anywhere? Pretbek Technical Discussion - V-650 2 12-26-2009 02:42 AM
I am a Rock, I am an Island... spiderman General Discussions - V-650 24 06-24-2009 03:46 PM
