Transmission or clutch problem - Kawasaki Versys Forum
post #1 of 3 (permalink) Old 12-14-2012, 07:17 AM Thread Starter
GAkawa's Avatar
HI guys,
I have a question about a 2004 Kawasaki vulcan 500.... I know this is the versys forum, ( I also own a 2009 versys ).
I went to start my wifes vulcan yesterday, the engine fired up just fine but I heard a noise that sounded like the starter was still spinning after the engine was running. I tried to put it in 1st, but it stayed in neutral. after a min I heard "crunching sounds" from the left side near the starter. I shut it off thinking the starter gears are stripped now and it wont start up. I turned the key and it fired right up again.... this time it went into first but wouldnt move forward with clutch released, I squeezed the clutch again and pushed forward with my feet and heard this "crunching sound" from the left side, more noticable than before. I shut it off and left it in the barn.
Any ideas as to what the problem is?
the bike only has 11,000 miles, oil level full, its been a smooth shifting and running bike since we bought it earlier this year.
thanks a bunch for you're help,
2009 Versys
Givi E21 side cases
Leo Vince exhaust
GAkawa is offline
post #2 of 3 (permalink) Old 12-14-2012, 08:50 AM
Lours_Polaire's Avatar
Clutch problem !!!
LOP
Lours_Polaire is offline
post #3 of 3 (permalink) Old 12-15-2012, 09:54 AM
I would suggest that you don't start it again. If you have a service manual and the tools and ability to fix something like this then go for it, otherwise I would say you need to take it to a bike shop.
Anytime you have symptoms like you describe, you need to open things up and do a investigation. A simple case of a clutch lever ball bearing falling out because the clutch is stuck, then getting into the gears, or a broken spring-----------next thing you are replacing your transmission .
