2007 Versys 650 Headlights problem - Kawasaki Versys Forum
 10Likes
post #1 of 27 (permalink) Old 05-03-2018, 02:25 PM Thread Starter
Hello everyone!
First of all, I apologize if this has been already posted, I tried to search for this issue but couldn't really find anything relevant.
According to the repair manual, the headlight low beam should only turn on after starting the engine, however on my bike the low beam goes on immediately after switching the ignition to on, and I can even toggle the high beam aswell.
The problem is that my headlight button acts as a switch, turning on the high beam will turn off the low beam so only one of them is active at all times, however the pass button will toggle high beam while pressed, alongside low beam.
During this problem my instrument cluster high beam indicator does not light up, even when the switch is on for high beam.
From my understanding and past experiences high beam and low beam should work together and not just only one of them selectively, right?
All the other lights from the instrument cluster work correctly, so what could cause all these issues? I'm decent with mechanical issues, but electrical stuff always beats me.
Any information is greatly appreciated.
Thank you in advance.
Verspkd is offline
post #2 of 27 (permalink) Old 05-03-2018, 02:37 PM
Originally Posted by Verspkd View Post
Hello everyone!
Low High beam switch is correct for the 2007, the passing switch is correct for the 2007. Turning on the headlight with a key switch only is a problem. Two tests I want you to do, it may require a mirror or a second person, observe if the headlight shuts off momentarily while pushing the start button. Second test is to disconnect the stator output wire socket if the headlight goes out during starting, also disconnect the plug going to the regulator, this will be tough but I don't think you want to replace the relay box if not needed.
Fastoman likes this.
post #3 of 27 (permalink) Old 05-03-2018, 02:49 PM Thread Starter
Are you the original owner? I can solve your problem but need more info, as well do you have the original stator and OEM regulator?
Hello onewizard, I am not the original owner, just purchased it recently, everything else works perfectly. From what I can tell, the stator cover was never taken off, also the regulator screws appear rusty and very hard to remove, I know it's a double edged sword but I do not think anyone replaced these. the bike has 43000 km at this point. For any other information, just ask and I'll do my best.
EDIT: So you are saying that both low beam and high beam cannot work at the same time ? only one of them of my choosing?
Could the relay being stuck also cause the high beam indicator to not light up on the instrument cluster?
I will attempt to do what you instructed, and will return with an answer tomorrow, as it's 11 PM already here.
EDIT 2: The headlight does appear to go very dim to almost closed when attempting to start the bike, this one at least I remember.
Verspkd is offline
post #4 of 27 (permalink) Old 05-03-2018, 08:11 PM
Low and high bean can work together. If you select low beam only low will work and if you select high, both low& high will work-2008 model.
post #5 of 27 (permalink) Old 05-03-2018, 08:20 PM
2007 the low beam / high beam switch is 1 pole double throw, the passing switch ties to the positive and high beam switch, on high the low is disabled according to the drawing, it has been too long for me to remember.
post #6 of 27 (permalink) Old 05-03-2018, 09:32 PM
will check it out later....you are right 1 pole double throw..but both L/H can also be active, as i said need to check it out.
"STAND TO BE CORRECTED."
post #7 of 27 (permalink) Old 05-04-2018, 04:59 AM Thread Starter
Thanks for the replies guys! Onewizard, what should I pay attention to when removing the stator plug? The lights just go a little dim when pressing the start button, but not that noticeable, just the normal current draw of the starter causing it.They do not go completely off.
EDIT: double checked with a friend that has the same model, high beam and low beam are both on at the same time when flipping the high beam switch, on his bike
EDIT 2: another weird thing that I tried, i flipped the high beam switch only midway, and both low beam and high beam stay on, flipping it after middle will close the low beam completely. This doesn t seem right
Verspkd is offline
post #8 of 27 (permalink) Old 05-04-2018, 08:39 AM
I have 07.
Key in with no engine = only city lights, no low beam.
Engine on = LB switch = LB
Engine on = HB switch = LB +HB
Pecko is offline
post #9 of 27 (permalink) Old 05-04-2018, 08:47 AM Thread Starter
Thanks Pecko, that's how it should work. I may have a relay issue and bad contacts hmm
Verspkd is offline
post #10 of 27 (permalink) Old 05-04-2018, 12:45 PM
Smiley's Avatar
I just checked my '07-
LB= low beam plus parking lights,
HB= high beam, low and parking lights too.
Smiley is offline
post #11 of 27 (permalink) Old 05-06-2018, 08:16 PM
Originally Posted by Pecko View Post
I have 07.
08 Model:-
Ignition ON- Parking lights ON
Start Idling - Low Beam only.
High Beam - All lights ON, HB /LB/Parking light.
sorry for the late reply.
post #12 of 27 (permalink) Old 05-07-2018, 09:59 AM Thread Starter
Thanks! Will post back when i get some time these days to fix it, hopefully without ordering any parts hehe.
Verspkd is offline
post #13 of 27 (permalink) Old 05-07-2018, 10:12 AM
Relay Box
FYI, I asked you to pull the 3 phase connector apart and disconnect the plug to the regulator, as you may have a damaged regulator ( which is powered all the time), you may also have a failed diode in the relay box, by disconnecting these two plugs, if your relay doesn't have
welded contacts, the headlight will remain off during and after starting
Next step would be to plug the 3 phase connector back in if the above test was positive with no light on.
Beyond these two tests, I need feedback from you.
post #14 of 27 (permalink) Old 05-07-2018, 10:45 AM Thread Starter
I was off on an unexpected trip with the bike these days however i am gonna attempt this tomorrow Onewizard, wasn't sure what to pay attention to when doing that. I think I can fix the High beam problem from the switch though but the light turning on with the ignition is most likely what you said.
But, do you mean disconnect the stator or pull all those 3 wires from their housing? should I do that and disconnect the regulator while the bike is running? could use some clarification so I don't screw things up. Thank you!
Verspkd is offline
post #15 of 27 (permalink) Old 05-07-2018, 12:06 PM
Thanks for the reply, more info of this post in How To Thread
post #16 of 27 (permalink) Old 05-07-2018, 12:42 PM Thread Starter
in my photo I have some wires going to the meters, see the How To Thread for clarification.
Thank you for the clarification, will report back with the observations tomorrow, fingers crossed. Also is it normal for this model to have the regulator near the back suspension/swingarm? it really seems weird placed in that swingarm cavity.
Verspkd is offline
post #17 of 27 (permalink) Old 05-08-2018, 07:31 AM
Feel lucky it isn't a Ninja, and yes, Kawasaki realized in 2015 that having a regulator near the rear wheel wasn't a good idea unless you lived in the desert. They also realized several locations were prone to electrical corrosion. The 2015 has at least 5 locations covered with rubber to protect from water that never existed on the MK-1.
post #18 of 27 (permalink) Old 05-08-2018, 08:32 PM
2007 Odd Ball Regulator
So after a flurry of PM I thought I should post this as it is extremely unusual when requesting someone to follow directions when the parts involved are different from anything seen before.
When asked to disconnect the plug to the regulatot there was some confusion and here is why:
post #19 of 27 (permalink) Old 05-09-2018, 12:19 PM
I attached a flap of "conveyor belt" to the underside of the seat area w/ a couple of pop-rivets, to shield the regulator from road crap, on both my '08 and '09 Vs.
NightRider likes this.
post #20 of 27 (permalink) Old 05-09-2018, 02:59 PM Thread Starter
Thanks! seems like a must do in this particular situation, will attempt something similar.
Verspkd is offline
