Oil from swing arm? - Kawasaki Versys Forum
Like Tree5Likes
  • 3 Post By hawkerjet
  • 2 Post By Randyjaco
post #1 of 6 (permalink) Old 04-14-2018, 07:53 PM Thread Starter
Randyjaco's Avatar
Oil from swing arm?
I was lubing the chain on my 2008 V today and noticed some water dripping from a weep hole at the rear of the swing arm. I used a small pick to clean out the debris from the hole. A couple of ounces of fluid came out. Then I touched the fluid and noticed that it was mostly oil. Is there any reason that a relatively large quantity of oil should be coming from the swing arm?
Randy
Randyjaco is offline
post #2 of 6 (permalink) Old 04-15-2018, 03:33 AM
If it really is some type of oil, maybe some chain lube overspray when applied by you or previous owner? Any oily water collected in the swingarm resulted from the weep hole being clogged.
http://www.kawasakiversys.com/forums...swingarms.html
invader is online now
post #3 of 6 (permalink) Old 04-15-2018, 08:41 AM
sternman318's Avatar
Oh jeez, m ore stuff to remember to maintain
sternman318 is offline
post #4 of 6 (permalink) Old 04-15-2018, 09:00 AM
hawkerjet's Avatar
Claim mineral rights and set up a derrick.
I wish I had light sweet crude oozing out at my house. Could use the income to supplement my retirement.
Cookin Wid Gas
hawkerjet is offline
post #5 of 6 (permalink) Old 04-15-2018, 09:27 AM
16VGTIDave's Avatar
Maybe the previous owner sprayed a corrosion inhibitor inside the swing arm, because they were well aware of the drain holes becoming plugged.
16VGTIDave is offline
post #6 of 6 (permalink) Old 04-16-2018, 06:39 PM Thread Starter
Randyjaco's Avatar
Thanks guys, I'm now thinking its probably chain lube.
But I will sell the mineral rights to the highest bidder B-)
Randy
invader and hawkerjet like this.
