Throttle problem question - Kawasaki Versys Forum
post #1 of 16 (permalink) Old 10-07-2012, 06:09 PM Thread Starter
So I was fixing the chain and sprocket on my girlfriends Versys and while that turned into a job and a half dealing with the front sprocket it got dealt with and all is well now in that area. But I've noticed a problem with the throttle and I'm not sure how to correct it. What looks to be the return cable (I've seen it called decelleration cable) seems to slide off the throttle tube and get stuck in between the body that holds it together and the plastic tube attached to the throttle handle. Is that indicative of a stretched cable? Or is that more a case of a bad throttle tube or casing?
The cable in reference is in blue below and the red arrow is referencing where the cable seems to be moving out of place. I can probably get a picture of it tomorrow. I was waffling on doing a bunch of work to it but she's decided she really likes the bike and wants to keep it so that means I want to make it as awesome as possible.
hawkbox is offline
post #2 of 16 (permalink) Old 10-07-2012, 11:21 PM
The return cable may need adjusting. You've opened the cover by the handgrip?
invader is online now
post #3 of 16 (permalink) Old 10-07-2012, 11:53 PM Thread Starter
Yep. Had to open it to fix the cable position, it lasted a little while and as near as I can tell I have tightened the return cable as far as it will go.
hawkbox is offline
post #4 of 16 (permalink) Old 10-08-2012, 12:08 AM
Weird... I can't tell what's happening with it from here.
It's tightened all the way, and there's still some slack? Something is surely wrong.
post #5 of 16 (permalink) Old 10-08-2012, 12:21 AM
According to service manual:
"Throttle Grip Free Play: 2-3 mm
If the throttle grip doesn’t return properly, check the throttle cable routing, grip free play, and cable damage. Then lubricate the throttle cable.
To adjust, loosen the locknut at the upper end of the accelerator cable. (under throttle grip) Turn the adjuster in completely so as to give the throttle grip plenty of play. Loosen the locknut at the middle of the decelerator cable. (see pic) Turn the adjuster until there is no play when the throttle grip is completely closed. Tighten the locknut. Turn the accelerator cable adjuster until the proper amount of throttle grip free play is obtained. Tighten the locknut."
You can easily pull the return cable adjuster that runs over the engine, adjust it then check with cable back up in its natural position. Shown here with locknut loosened and backed up to the right:
post #6 of 16 (permalink) Old 10-08-2012, 12:26 AM Thread Starter
Yeah I did that and it helped, but not enough. I'm gonna take a picture of it tomorrow
hawkbox is offline
post #7 of 16 (permalink) Old 10-08-2012, 06:09 AM
offcamber's Avatar
IS it possible the cable is stretched or internally damaged where it can't be seen, causing it to be a lot longer than is should be? I had a similar issue with a clutch cable but the damage was at the end and was obvious.
" I don't care about shinny chrome or loud exhaust, I don't ride to be seen, I ride because I want to disappear"
Halfthrottle
offcamber is offline
post #8 of 16 (permalink) Old 10-08-2012, 08:03 AM
Check if throttle cable is pinched.
post #9 of 16 (permalink) Old 10-08-2012, 11:31 AM Thread Starter
It's certainly possible and it's my primary concern. Also the kinking issue might be a problem. I'll go check it this morning and see what I can figure out.
hawkbox is offline
post #10 of 16 (permalink) Old 10-08-2012, 02:56 PM Thread Starter
Ok so I went out and removed the return cable from the arrangement and that seemed to have helped a lot. The cable is still a bit slack so I suspect I need to look into replacing it but hopefully my temporary solution doesn't set off any alarm bells with people.
This is what it looked like when I opened the casing
And the cable was bent and not good looking
So I disconnected it from both ends and moved the existing cable to use a bit more of the slack for the rest of fall so I can swap them out while it's in storage.
hawkbox is offline
post #11 of 16 (permalink) Old 10-08-2012, 07:48 PM
Yeah it got kinked at some point, maybe when it got too slack... You're fine without the return cable hooked up for now. Throttle does not tend to stick open on its own at all. You would only really need it to pass safety check.
So it's a bit slack still at its tightest position? I guess you just need a new throttle cable set.
post #12 of 16 (permalink) Old 10-08-2012, 09:37 PM Thread Starter
That's kind of what I thought, but wanted to get some addition insight. I'll just order up a cable set over the winter and prep it for spring, I still need to properly bleed the damned back brakes so they do something rather than nothing and I'm ****ty at that.
hawkbox is offline
post #13 of 16 (permalink) Old 10-09-2012, 01:25 PM
Beg, borrow or steal a vacuum bleeder. EASY!
post #14 of 16 (permalink) Old 10-09-2012, 03:57 PM
acinonyx's Avatar
Actually, only the throttle cable is adjustable (not the return cable).
You can easily pull the mid-cable adjuster that runs over the engine, adjust it then check with cable back up in its natural position. Shown here with locknut loosened and backed up to the right:
Actually, there is an adjustment for both cables. (Pic from Page 2-15 of manual.) I may have this backward, but I believe the adjuster for the decel cable is on the handle bar (underneath) and the adjust for the accel cable is inline, close to where the cable is connected to the spool on the throttle body assy. (This one is quite hidden -- you'll have to search for it. Invader has it pictured above.)
-Never mistake kindness for weakness.
-Harley Davidson rEvolution engine (V-Rod): Designed by Porsche, detuned by Harley.
acinonyx is offline
post #15 of 16 (permalink) Old 10-10-2012, 04:10 AM Thread Starter
I found both of those yeah, and it made a difference but not a huge one. I may just be spoiled right now by the tighter tolerances of my Triumph too, which I suppose I should expect more out of a bike twice the price.
hawkbox is offline
post #16 of 16 (permalink) Old 10-10-2012, 05:00 AM
Lightbulb
Oh yeah, the upper cable's adjuster on my pic is the return cable... Tightening the return cable rotates the throttle grip in the same direction as when opening the throttle valves, which also reduces cable slack.
