Correlation between vacuum sync and vibration! - Kawasaki Versys Forum
post #1 of 3 (permalink) Old 10-07-2012, 02:27 PM Thread Starter
Sprocket's Avatar
Recently balanced the vacuum between the two throttle bodies and since then have noticed a noticeable reduction in vibration, especially in the 5-6K range. It was not off much so the correction required was small but it still had a very noticeable effect on vibration. Anyone else notice this? Took less than 2 minutes to do - if you don't include the time required for gas tank removal and re-installation. Used this tool.
Sprocket is offline
post #2 of 3 (permalink) Old 10-07-2012, 05:24 PM
AzItLies's Avatar
x
AzItLies is offline
post #3 of 3 (permalink) Old 10-11-2012, 09:21 AM
Mursili's Avatar
The tool is even unnecessary. I successfully used a length of thin flexible tubing that I filled with water and hung from a ladder to create a manometer. The hardest part was filling the tube with water and getting all of the bubbles out...
I can't say I noticed anything different after I balanced the throttle bodies, but I will try to notice next time.
Mursili is offline
Tags
vacuum sync
