headlight issue - Kawasaki Versys Forum
post #1 of 11 (permalink) Old 09-28-2012, 03:14 PM Thread Starter
headlight issue
Was out after dark last night,stopped to get fuel,and when I started back up,my headlight didn't come back on...Turned the key off,started back up,and it came on....Went out a few minutes ago,started up,and no light...Turned off the key,started again,and this time there was about a 2 or 3 second delay before the light came on....This is on an 08.....Is there a relay for the headlight that could be going bad? All fuses and connections seem to be good....It never flickered last night after it came back on,so I am not thinking in the lines of a short....There has to be a switch somewhere that turns it on when the engine starts....
Hoodlum
hoodlum is offline
post #2 of 11 (permalink) Old 09-28-2012, 03:25 PM
Tigerpawed's Avatar
Service manuals in this thread: http://www.kawasakiversys.com/forums...ead.php?t=2846
Tigerpawed is offline
post #3 of 11 (permalink) Old 09-28-2012, 03:45 PM
Is it the same with high and low beam? If it's a low beam only issue it may just be your bulb is about to die.
[SIZE="1"]Ride. Good.
2019 F750GS
2014 R1200RT
2008 Versys (SOLD 11/19)
2003 ST1300ABS (SOLD 5/15)
post #4 of 11 (permalink) Old 09-28-2012, 08:15 PM
Good point, when it happens try high beam, if that does work, then you have a low beam bulb or bulb connection problem. The low and high beam are powered by the same relay circuit. I would be more inclined that the relay is going, from what I have seen in the wiring diagram, the headlight relay is part of a relay box assembly . The headlight comes on after the starter button is released, headlight goes out momentarily when the starter button is pressed.
post #5 of 11 (permalink) Old 09-29-2012, 07:41 AM Thread Starter
Thanks for the response...It is both high and low beam.....I have concluded a new relay box is in order,and on order....
Hoodlum
hoodlum is offline
post #6 of 11 (permalink) Old 09-29-2012, 05:10 PM
Mursili's Avatar
Good luck.
Please tell us how the new relay box works out. This issue is new to me.
Mursili is offline
post #7 of 11 (permalink) Old 09-30-2012, 09:53 AM
A2RON's Avatar
I had a "similar" sounding problem with my 2008. Replacement of the starter relay (a.k.a. magnetic switch P/N 27010-1446) ultimately (I changed the relay package and the headlight issue persisted) fixed the problem.
A2ron
Charleston, SC
A2RON is offline
post #8 of 11 (permalink) Old 10-02-2012, 07:36 AM Thread Starter
So help me understand....Are you saying the starter selenoid fixed the problem? I didn't realise the headlight went through it...I will keep that in mind if the relay doesn't fix the problem...I am hoping it will be here today or tomorrow....
Hoodlum
hoodlum is offline
post #9 of 11 (permalink) Old 10-02-2012, 03:00 PM
A2RON's Avatar
Hoodlum
You don't say what year your Versys is, but the Shop Manual for my 08, Electrical System 16-59 shows the starter relay (a.k.a the "magnetic switch") going to the headlight relay. Since I changed the relay package (contains the headlight relay) and it didn't fix the problem, changing the magnetic switch got the headlights working again.....for the last 3,000 miles to date.
The magnetic switch is under the small triangle access cover on the LH side of the bike, this is with the cover removed:
A2ron
Charleston, SC
A2RON is offline
post #10 of 11 (permalink) Old 10-02-2012, 04:00 PM
Boricua's Avatar
When everything else fails and the instructions are not helpful. Seek a qualified technician.
Boricua is offline
post #11 of 11 (permalink) Old 10-03-2012, 07:53 AM Thread Starter
Nothing has failed yet...My selenoid box should be here today....
hoodlum is offline
