Does the fork "use all its travel" or not? - Kawasaki Versys Forum
post #1 of 9 (permalink) Old 09-14-2012, 10:54 PM Thread Starter
I've got a 54mm dirty part at the bottom of my lower fork legs that never gets used. And several mm more that look like they haven't been used in a long time.
When I took my fork to a suspension guy to get a custom shim stack, he told me that the fork bottoms out right there, and the dirty part of the fork leg is unusable. He determined that when he was inside the fork--he hadn't done a Versys fork before.
Recently I had a race mechanic do some other service on my bike. He warned me about the dirty spot telling me I wasn't getting close to full travel. When I told him what the suspension guy told me, he was willing to give him the benefit of the doubt based on his reputation, but he hadn't seen anything like it before. And like me he was thinking of asking around.
So what's the real story here? Does the fork bottom out with 54mm of the lower leg exposed? How much of the lower leg shows when the fork is bottomed out?
davidg is offline
post #2 of 9 (permalink) Old 09-14-2012, 11:08 PM
Sprocket's Avatar
One trick is to put a plastic wire tie around one of the front fork tubes and push it up to the fork seal. You can use this to monitor max suspension travel on a ride. Suspect most of the travel is used during hard braking.
Sprocket is offline
post #3 of 9 (permalink) Old 09-14-2012, 11:27 PM Thread Starter
I have one on there. Whether I'm going by the dirt or the cable tie though, there's 54mm of the lower leg that has never been used on my bike, and I'm wondering if it's useable.
davidg is offline
post #4 of 9 (permalink) Old 09-14-2012, 11:38 PM
I get just over 6" of fork travel when they do bottom out.
http://www.kawasakiversys.com/forums...ad.php?t=18133
invader is online now
post #5 of 9 (permalink) Old 09-14-2012, 11:52 PM
AzItLies's Avatar
x
AzItLies is offline
post #6 of 9 (permalink) Old 09-15-2012, 12:28 AM Thread Starter
Interesting mod, thanks!
davidg is offline
post #7 of 9 (permalink) Old 09-15-2012, 11:22 PM
If you're not too heavy, you will probably ONLY get full travel if you're extremely aggressive, or hit BIG potholes FAST!
post #8 of 9 (permalink) Old 09-16-2012, 02:33 PM
GusG's Avatar
I have the preload with only 1 turn from 0 and I still get pretty far from bottoming it out. I only weight 60 kg
GusG is offline
post #9 of 9 (permalink) Old 09-16-2012, 02:44 PM Thread Starter
1. Do you actually know where in the travel bottoming out occurs?
2. Why do you have any preload at all?
I know there are people who've determined the answer to my question while working on their fork, and I hoped someone might say. From looking at the extended travel thread it appears that if it isn't bottomed out with 54mm showing, it's getting close.
davidg is offline
