Newbie Question - Kawasaki Versys Forum
 3Likes
  • 2 Post By Brockie
  • 1 Post By Ed96
post #1 of 10 (permalink) Old 01-24-2018, 07:01 PM Thread Starter
Ed96's Avatar
Newbie Question
Is this coolant fluid ok? I'm new to working on my bike so wondering if this is normal for coolant fluid. Thanks!!
Ed96 is offline
post #2 of 10 (permalink) Old 01-24-2018, 07:53 PM
Brockie's Avatar
Unless you are a poor photographer it looks a little polluted to me and as the level is getting towards the Low mark it may have never been changed. It should be a clear green color.
There are some suggestions here: http://www.kawasakiversys.com/forums...e-coolant.html
And here (look at Invaders post #5) http://www.kawasakiversys.com/forums...e-coolant.html
Kawasaki recommends replacement every 3 years.
Brockie is offline
post #3 of 10 (permalink) Old 01-25-2018, 08:07 AM
Looks like time for a flush and refill to me!
Jack of Heats JoH is offline
post #4 of 10 (permalink) Old 01-25-2018, 11:03 AM
At the co$t of replacing your antifreeze, I'd suggest just do it, and use distilled water as the mix, as well as for the system cleaning.
post #5 of 10 (permalink) Old 01-25-2018, 11:53 AM Thread Starter
Ed96's Avatar
Thanks so much. Agreed! Now it's time to start plumbing YouTube and figure out how to do it!
Brockie likes this.
Ed96 is offline
post #6 of 10 (permalink) Old 01-25-2018, 12:03 PM
its really easy ,first remove the right tank plastic, then on the right side of the motor is the water pump and the lower bolt on it is a drain plug, remove that (with a drain pan under it) once empty flush with about 1/2 gallon of distilled water, then put the plug back in and fill the system with distilled water, burp the system (squeeze the rab hoses to help push the air out of the system) run the bike a bit till warmed up, then drain the water out and then refill with a proper mix of 50/50 coolant/distilled water, burp it again and ride on
post #7 of 10 (permalink) Old 01-25-2018, 03:32 PM
Download the service manual. Details are in there. I keep a copy on my phone has come in handy more than once!
post #8 of 10 (permalink) Old 01-26-2018, 08:36 AM
AngryGazebo's Avatar
Anyone have any experience with Evan's water-less coolant? I remember seeing something about it on Jay Leno's Garage and was always curious but figured it would be too expensive for a daily car but might be worth it on the bike. It is supposed to last the lifetime of the engine(never need to be replaced) and has a higher boiling temp than water so better for high performance engines.
https://www.evanscoolant.com/product...ports-coolant/
https://www.evanscoolant.com/how-it-works/
AngryGazebo is offline
post #9 of 10 (permalink) Old 01-26-2018, 05:24 PM
Brockie's Avatar
I tend to bypass manufacturers hype and google for the independent opinion. In this case it came out good.
https://www.norosion.com/evanstest.htm
https://www.amazon.com/product-reviews/B00TPVI2TQ
Brockie is offline
post #10 of 10 (permalink) Old 01-26-2018, 06:20 PM
just remember that is a coolant not an anti freeze, leno can get away with using it in all his cars because they are kept in a garage nicer them most of our houses xD but i know of quite a few people that use it in there track bikes
