Be aware! - Kawasaki Versys Forum
Like Tree16Likes
  • 2 Post By fasteddiecopeman
  • 1 Post By Rebel13
  • 2 Post By hawkerjet
  • 2 Post By Zenner
  • 4 Post By TowerMan
  • 2 Post By Rebel13
  • 1 Post By Rebel13
  • 1 Post By steve1503
  • 1 Post By alpy
post #1 of 20 (permalink) Old 12-08-2017, 12:27 PM Thread Starter
steve1503's Avatar
Be aware!
Sadly, but not surprising, my seat riser broke.
I went out to remove the battery, with snow in the forecast, I found that the 3D printed riser cracked and in pieces.
If you have one you may want to check it.
Name:	3d riser broken.jpg
steve1503 is offline
post #2 of 20 (permalink) Old 12-08-2017, 12:48 PM
Sorry to hear that, Steve. Suggest you replace it w/ a piece of scrap steel and about 12 = 1/4" washers. That's lasted for about 145,000 miles on MY Versys'.
ID:	138105   Click image for larger version
ID:	138113   Click image for larger version
Name:	111seat rise2 copy.jpg
quexpress and Duffy like this.
post #3 of 20 (permalink) Old 12-08-2017, 09:53 PM
Rebel13's Avatar
Obviously it is made out of a material not built for the stress of the riders weight in action, I'm not suprised about that, the manufactures failed design. Most of you are not supporting the seat completely to begin with while doing this mod. I'm suprised you guys are not deforming/weakening the seat tangs, maybe you are but don't know it?
Rebel13 is offline
post #4 of 20 (permalink) Old 12-08-2017, 11:08 PM
hawkerjet's Avatar
I did a mod on my stock seat. I removed the cover and dished out the foam where my butt sits.
In addition to being more comfortable, this mod pretty much eliminated the slide forward issue.
Hey that would be a twofer...2 fer the price of 1.
Actually total cost was zero.
onewizard and Duffy like this.
Cookin Wid Gas
hawkerjet is offline
post #5 of 20 (permalink) Old 12-10-2017, 02:17 PM
Over 145,000 miles on my Vs - NOTHING has broken from the mod I included pics of.
post #6 of 20 (permalink) Old 12-10-2017, 04:15 PM
Rebel13's Avatar
It's about applied forces, not mileage. The whole point of the mod is to shift the riders weight rerward of the seat, thus reducing weight on the front/modded area to start with. Keep in mind that even though your body is not putting as much weight on the front tang doing this, it is still getting constant force appied do to the pan curvatures resistance. Doing this mod will curve the set pan some in time. However, what I was talking about not supporting the seat properly is about the pan and the mod. Most to all of you (you included) secure in only one place, the primary tang. There are actually three forward mounting points, not one! The other two that most of you skip keeps the pan level to prevent twisting along with weight distribution. Using only one point, added weight and the twisting can weaken or break the primary tang.
How heavy one is and how one sits and uses the seat means everything. Using a weak plastic like the 3d printer has made was not adequate for the applied forces and failed as a result.
Rebel13 is offline
post #7 of 20 (permalink) Old 12-10-2017, 05:50 PM
I was concerned about the strength of this mod when exposed to 10 degree weather since it puts a lot of pressure on a piece of plastic. I'll rely on fasteddiecopeman's mod for safety. Easy, simple, cheap, reliable, and strong. My kind of mod.
Skypilot 69 and funflyingguy like this.
Zenner is offline
post #8 of 20 (permalink) Old 12-10-2017, 06:46 PM
Iíve got the printed one, but I guess Iím safe regarding 10į temperatures here in California. Iíll keep a close eye on it though for sure.
Buffalo_Bob is online now
post #9 of 20 (permalink) Old 12-16-2017, 02:03 PM
TowerMan's Avatar
Be aware that the plastic tongue on the front of the seat is not designed to be load bearing
On the following pictures I have marked up where the seat is supported on the front metal cross brace and what on the seat rests on it.
Whilst raising the seat in this way no one yet I believe has had a tab break, it still could
When I tried this mod it always felt that the seat was wobbling side to side on the twisties here in Scotland
Ended up remodeling the front of the seat / raising the nose from details gained from this website - DIY Motorcycle Seat
Richard
at
TowerMan is offline
post #10 of 20 (permalink) Old 12-16-2017, 09:07 PM
motorboy's Avatar
Richard
Being I don't do pictures it would have been hard to explain what I did to raise the seat but with these excellent pictures here goes- on the plate under the tank(first picture) where the seat tabs touches- I drilled a hole and used a 6mm to line up with the tabs on the seat(second pictures- I used large flat head 6mm screws and small 2mm thick washers on the screws to adjust how high I wanted the seat and tried a different amount of washers on the added metal bar that the front seat tang now fits into and ended up with 10mm higher because at that height the seat just touches the tank- to keep the seat from wobbling on the frame I used 2mm flat sheet rubber a piece at a time(took two pieces each side) duck taped to the frame where the seat rests- no wobbling-hope this makes sense because it worked very well
Deep in Cajun Country
motorboy is offline
post #11 of 20 (permalink) Old 12-16-2017, 11:16 PM
Rebel13's Avatar
Richard
Bingo! This is exactly what I was talking about with three points of stability and weight distribution! Rest assure, I have the appropriate cheap mod with visuals for you! Simply use HDPE! Fairly light, very easily workable, very strong and weather resistant! Mine is 3/8" across the board. The amount you lift this way is actual and limited by your own specs.
Oh, and did I mention most of you are liftig the seat wrong to begin with? That large tang doesn't rest on the tank lip, but on the cross brace, thus the different measurements of cause and effect you face~
16VGTIDave and kardan like this.
Rebel13 is offline
post #12 of 20 (permalink) Old 12-17-2017, 06:23 AM Thread Starter
steve1503's Avatar
Nice back rest, and thanks for the input on the lift.
post #13 of 20 (permalink) Old 12-17-2017, 08:12 AM
Rebel13,
What did you use to secure the HDP plate to the frame? Think I will stop by the dollar tree and pick up a cutting board for $1 they are pretty thin so I may need 3 or 4 layers, will be good practice on the scroll saw, havenít used it in a while.
JoH
Jack of Heats JoH is offline
post #14 of 20 (permalink) Old 12-17-2017, 08:55 AM
Now Youv'e Done IT
OK we now need a full step by step HOW TO for that back rest, c/w photos. Once complete I will copy to the appropriate thread. As to your lift , that is 100% correct, I posted this some time ago, in fact your mod is almost identical to my initial mod http://www.kawasakiversys.com/forums/1348218-post9.html
However I didn't like this for 2 reasons, one was I had lowered the bike as I have a 30 inch inseam, second was it did nothing to correct the curvature of the foam, so that mod remained for 2 days and was then removed. I redid my seat foam and it is a huge improvement. I would be interested in how you made that back rest, more importantly how it is attached and supported.
post #15 of 20 (permalink) Old 12-17-2017, 09:25 AM
Rebel13's Avatar
The HDPE is secured with 3M double sided tape, real simple. It is secured, the seat also keeps it still. As you can see, my bike is lowered and there is no chance of ride up anyway before or after the mod, but I wanted it to keep me planted reward in the seat. Now the Ninja 650, major ride up, but I haven't done anything for it as of yet. Not sure if I ever will, after 10 years of use, I'm use to it.
Rebel13 is offline
post #16 of 20 (permalink) Old 12-17-2017, 11:57 AM
Richard
Thanks - some THOUGHTFUL modding here!
I did my first seat in '08, as a huge number of Versys riders were doing it - I just "tagged-along" - and it has worked so well that I kept doing it, sharing it w/ others here on the Forum as a GOOD, CHEAP mod to make the seat LESS restrictive. Thus far, NONE of my seats have 'failed' - two Gen 1s; one Gen 3, altho' I CAN see the value of this extra mod!
post #17 of 20 (permalink) Old 01-23-2018, 04:16 PM
Has anyone reached out to our member Rockstar who designed and made these things that many of us purchased???
rayj
2009 Versys (Mine's Green)
rayj is offline
post #18 of 20 (permalink) Old 01-23-2018, 04:50 PM Thread Starter
steve1503's Avatar
I did not, and do not expect anything from him. It was a good idea, just needs a bit more support.
post #19 of 20 (permalink) Old 01-08-2020, 03:03 AM
alpy's Avatar
Hi,
If there is still an interest in 3D printed riser blocks, I made my own which provides the support at original locations of the seat, but adding 12mm height.
https://www.thingiverse.com/thing:4089614
Cheers,
Alpy
turn8a likes this.
V650/2015
alpy is offline
post #20 of 20 (permalink) Old 01-08-2020, 08:54 AM
hawkerjet's Avatar
There is another option fellas.
How bout if you lower the center and rear portion of the seat.
I carved out some foam in the center and rear portions which accomplished 3 things. Got rid of the forward slope, got my feet closer to the ground and made the seat much more comfortable. The following describes the process.
https://www.kawasakiversys.com/forum...t-tune-up.html
Cookin Wid Gas
