2014 650 Versys Numerous Problems - Kawasaki Versys Forum
Like Tree1Likes
  • 1 Post By Kensei77
post #1 of 9 (permalink) Old 11-14-2017, 08:40 AM Thread Starter
Kensei77's Avatar
Hi,
I'm new to the forums. I've had my 2014 Versys 650 since November of last year and ride it daily as my daily rider regardless of the weather condition. I'm not new to motorcycles, I've been riding off and on for 25+ years, with the last 6 years consistently.
I love anything on two wheels, bicycles, mopeds, motorcycles. I also enjoy riding ATVs.
I decided to sign up today for two reasons: one; looking to find other Versys riders in my area to maybe do rides with, and two; my Versys is starting to have multiple problems all at once and I need help troubleshooting. But more about that later.
Kensei77 is offline
post #2 of 9 (permalink) Old 11-17-2017, 09:12 PM Thread Starter
Kensei77's Avatar
Sorry, havenít been online for a couple of days. Thanks to everyone for the welcomes.
So, Iíll try and explain my issues the best I can. It seems Iím getting plagued with multiple problems all at once.
My bike is a 2014 with 13k miles. No modifications mechanically.
First off, Iíve had a flat spot at around 9k rpms for a while. I recently changed the spark plugs and that help with the flat spot, although itís still there a little.
Right plug was brownish and the left plug was more white. Also, thereís discoloration with the headers. Left pipe looks dull like a powder is over it and the other looks normal. Iíll try and post pictures soon.
The bike is now running really smooth through gear 1-4. The problems are when I hit 5th and 6th gears. As long as I donít try and accelerate it seems ok, but once I get on the throttle, even lightly it sounds very throaty, vibrates and doesnít want to accelerate fast.
To get the full idea, imagine being in a gear at around 2k rpms and you try and accelerate. Youíre too low in the rpms range and it struggles. Thatís the exact same reaction the bike is having in 5th and 6th but my rpms are over 5k rpms.
Another thing is I sometime smell burnt wires, usually Iíve noticed it more in the rain after riding. The last time I rode it in the rain it was pouring and the high beam indicator light on the gauges lightly came on. At the time the high beam bulb had been out. Iíve had to change it 3 times in one year because the light goes out prematurely.
And lastly Iíve noticed is a howling at around 55 mph. As soon as I hit 55, no matter the gear from what I can tell.
So, as you can see Iím having some issues. I took it to the dealer and they did a throttle body sync and said it was good. I took it home and nothing changed. I complained to the owner and left it at that. Going to do my own work like usual, but at that time I just wanted it fixed.
Any input would greatly be appreciated.
Thank you for reading.
Kensei77 is offline
post #3 of 9 (permalink) Old 11-18-2017, 06:22 PM Thread Starter
Kensei77's Avatar
I tried uploading some pics but not sure how to。Also、last night I took all the fairing off the bike and checked every wire, plug and hose for problems or anything abnormal. I didnít find anything. Also checked the plugs and all looked good.
Today I took it for a ride and the bike did better. I noticed that if I get it over 5.5k the bike starts to smooth out in fifth and sixth. Iíve always shifted at 4500rpms and have never had it run like this before.
Not sure if the clutch going bad could do this. Iíve noticed also the shifter feels rough when I shift up in gears, but ok when shifting down.
Does that sound like a clutch problem?
Either way, Iím ordering clutch plates and going to change them out.
Anyway, thanks for reading and hope to hear some feedback.
Have a great weekend!
Kensei77 is offline
post #4 of 9 (permalink) Old 11-18-2017, 07:58 PM
Some other things:
Does it feel as the bike is being held back?
I'm assuming you have checked the air filter?
Checked the final drive for chain alignment and chain not too tight or tight spots. If it has tight spots you can hear a WA-WA-WA-WA sound at speed.
If wheel/chain alignment is off you can get brake drag too.
Buffalo_Bob is offline
post #5 of 9 (permalink) Old 11-20-2017, 09:41 AM Thread Starter
Kensei77's Avatar
It does feel a little held back in 5th a 6th.
Also, the air filter is good. I changed it out a month or so ago and still looks good as of the other day. Chain is about 2 months old and in good condition and clean.
Today I rode it to work (37 degrees F), and it seemed just as rough as it did originally. With my commute one way being an hour, I could monitor and judge it more. I noticed that when cruising in 5th or 6th while just holding the throttle to maintain speed all is smooth. Anytime in those gears I give it throttle, whether it be hard throttle or slowly, it seems to struggle a little and feels rough. If I get the rpms over 5.5k rpms, it's a little better.
A little over halfway of my trip and after holding it at 80 mph the bike seemed to have smoothed out a little. I eventually had to stop and warm my hands on the exhaust for a few minutes. When I did I could smell the burning rubber/wire burning smell again.
After a few minutes I got back on the bike and continued to work, in which accelerating quickly to get on the highway all seemed smoother. In the end though, all seems the same for the most part.
I'll also add that I put about a half a tank of ethanol free gas in that my neighbor had given me the other day. Not sure if it ran a little smoother later on due to the gas running through the system or not.
Anyway, that's all I got so far. I'll see how it runs after work. I'm hoping the problem will just magically fix itself...lol
Kensei77 is offline
post #6 of 9 (permalink) Old 11-20-2017, 11:01 AM Thread Starter
Kensei77's Avatar
Was just thinking. Maybe an engine mount?
Kensei77 is offline
post #7 of 9 (permalink) Old 11-21-2017, 09:51 AM Thread Starter
Kensei77's Avatar
Thank you very much for moving my post and for the input. I'm pretty random when getting on here, sometimes I just go straight to my original post on my phone and then just log out.
Again, thanks for the input. Going to try the upload pics when I have time. I'm typing from work now, when I get home I bend to the needs and wants of my 2 yo and 9 yo. Haha.
Kensei77 is offline
post #8 of 9 (permalink) Old 11-21-2017, 09:51 AM Thread Starter
Kensei77's Avatar
Dang, the pic uploaded. Haha.
That's the discolored headers.
Kensei77 is offline
post #9 of 9 (permalink) Old 11-21-2017, 01:21 PM
Originally Posted by Kensei77 View Post
...That's the discolored headers.
To me - it just looks like the FRONT header is 'dirty', but near the top above the muddy bit, the color looks the same to me as on your other pipe.
