Cannot get clutch cable to connect - Kawasaki Versys Forum
post #1 of 5 (permalink) Old 10-26-2017, 07:22 AM Thread Starter
Having a strange issue. Had to replace my frayed clutch cable on my 07 Versys. I've routed it through the bike but the little metal spigot that clips through the clutch loop, I cannot for the life of me get it through the little link. I spent a hour fiddling with it, then my mate who has a far better mechanical knowledge that me so had a go, ..with no luck. It just won't fit through the link properly.
Anyone have any tips for getting it on? It's the correct cable. The old one popped off quite easily.
Coopz is offline
post #2 of 5 (permalink) Old 10-26-2017, 12:52 PM
are you trying to hook the clutch end first or have the handle end first? and also did you take all the slack out of the middle adjuster?
post #3 of 5 (permalink) Old 10-26-2017, 03:32 PM Thread Starter
Clutch end first, the cable has been threaded through to the handle but not connected.
Coopz is offline
post #4 of 5 (permalink) Old 10-26-2017, 04:57 PM
is the middle adjuster fully tightened in? after doing that ive always found getting the end into the clutch arm first (rest of the cable free) then pull the sheath part up into its holder, then get the barrel part in to the lever and start removing slack by adjusting the middle adjuster first to take out 3/4 of the slack then use the one at the handle for the rest
post #5 of 5 (permalink) Old 10-26-2017, 07:12 PM Thread Starter
Thanks mate, was able to get it in, it was just extremely fiddly, done a few cables in the past, first time I really struggled with a simple job=p
Coopz is offline
