A MURPHY while finishing a valve-adjust... - Kawasaki Versys Forum
Like Tree6Likes
  • 5 Post By fasteddiecopeman
  • 1 Post By chadams66
post #1 of 6 (permalink) Old 09-15-2017, 12:53 PM Thread Starter
After I re-installed the gas tank yesterday at the 'finish' of my valve-adjust, I visually checked things, then 'hit' the starter.
SOMETHING was wrong - it 'ran', but VERY poorly w/ the smell of un-burned fuel, and stalled as soon as I let go of the throttle. Tried it twice - SAME result, so I turned the ignition OFF, steeling myself to taking it ALL apart to find where I'd done something wrong.
I pulled my stool over by the left side of the engine to give it a 'visual' before I wrenched, and saw that I had "MURPHIED" the two connectors that go just below the tank on that side (left), when I had re-connected the two electronic sensors from ABOVE while re-installing the throttle-bodies. EASY to do as they're identical except for color.
I'm attaching two pics of them, and from the side it's EASY to see which goes where. (As an aside - it SURE ran awful when connected the way I had inadvertently done, so I DON'T recommend doing it that way!)
ID:	132553   Click image for larger version
post #2 of 6 (permalink) Old 09-15-2017, 03:27 PM
At least it was a simple fix...
post #3 of 6 (permalink) Old 09-15-2017, 04:42 PM
Indelibility's Avatar
Agreed
Indelibility is offline
post #4 of 6 (permalink) Old 09-15-2017, 10:11 PM
chadams66's Avatar
fire that mechanic and demand a refund...
Urbanengineer likes this.
chadams66 is offline
post #5 of 6 (permalink) Old 09-16-2017, 11:00 AM
at least you found it before you started taking the bike apart again
post #6 of 6 (permalink) Old 09-16-2017, 05:03 PM Thread Starter
I TRIED, but he told me to STUFF IT, then went and grabbed a beer....
THOSE were MY thoughts TOO!!!
