Coolant Temp Indicator - Kawasaki Versys Forum
post #1 of 4 (permalink) Old 10-29-2008, 04:41 AM Thread Starter
THR
Hi there... I just bought my new V 22 days ago! I'm from Malaysia n' the bike is similar to our friend in Canada (read: Canadian's spec). Just wondering is it normal for the coolant indicator at meter cluster/guage for not lit up when we put the ignition switch at 'on' position, before we crank the motor? So far i only saw oil pressure n' FI indicators being lit up for system self diagnosed n' not the coolant temp indicator. Shouldn't the coolant temp indicator lit up too for the same reason? Thank you...
THR is offline
post #2 of 4 (permalink) Old 10-29-2008, 12:43 PM
amir_zwara's Avatar
I'm not sure, I will check in a few minutes and post back to ya when I get to work.
amir_zwara is offline
post #3 of 4 (permalink) Old 10-29-2008, 01:27 PM
amir_zwara's Avatar
So over here in the US, the rad. collant light does NOT turn on when the rest of those dashboard lights do.
I guess it only turns on when you need it to... but how do you know if the bulb is still any good or not if you can't check it on a normal basis?
post #4 of 4 (permalink) Old 10-29-2008, 09:49 PM Thread Starter
THR
Yes... that is my main concern. how do we know if the bulb is working...
So the summary is, the coolant/radiator indicator does not lit up to tell ya whether they working or not. Thanks amir.
THR is offline
