2007 Versys - Cooling issue - any ideas ? - Kawasaki Versys Forum
post #1 of 6 (permalink) Old 06-05-2012, 02:10 PM Thread Starter
browny181's Avatar
Just bought secondhand 57 plated Versys GT. Didn't come with the original panniers, so I've had to buy new Givi V35's, but they look great..
I think I might have an issue that didn't come to light at purchase.
Bike runs fine, very responsive, great riding position.. However, when I've come to the end of a journey longer than 15 mins, I'm noticing an amount of coolant being dumped from the overflow pipe.
This has happened several times now. When in traffic last week, the temperature light came on. I moved off to find somewhere to stop, and the light went out, presumably as I was moving again and the rad was receiving an amount of cooling having not been in traffic any longer.
A fellow Versys owner has asked if the cooling fan is coming on - which it isn't. So there's clearly a problem; however..
Does the thermostat on the Versys control when the cooling fan kicks in ?
Or does the cooling fan have its own temperature sensor ?
I think I'm obviously gonna have to do some kind of fix - but don't want to start with the thermostat if it isn't linked to the cooling fan working..
Any help or advice greatly appreciated.. Many thanks
Sent from my Motorcycle iPhone app
browny181 is offline
post #2 of 6 (permalink) Old 06-12-2012, 11:12 AM
2daMax's Avatar
IF the fan is not coming on, try moving the blades to see if there is free play. Chances are it may be stuck due to stone chips got wedged in and burn out the fan.
The temperature sender unit, located under the Throttle Body, monitors the coolant temps and the ECU turns on or off the FAN. If the Fan is fine, check the radiator cap, it could be stuck cap.
The thermostat, is unlikely to cause an overheat, it usually cause overcooling as when it gets stuck, it is normally in the open wide position. If you check it, a stuck thermostat should have scratch marks all over it where the bi metals move w.r.t one another.
Previous Ride:
My V's Farkle Log:
2daMax is offline
post #3 of 6 (permalink) Old 06-13-2012, 11:10 AM
Baron650's Avatar
Likely the fan, and check the fuse if the fan seems free to move.
If all that's alright, then it might be the Cap. I'd replace it.
Drain and flush the radiator, refill with fresh 50/50.
Baron650 is offline
post #4 of 6 (permalink) Old 06-13-2012, 07:42 PM
Some info on my recent post on cooling and Fan activation Temp.
http://www.kawasakiversys.com/forums...ad.php?t=19815
I went this way as I can have a back up system independent from the factory settings which I can manually control to my desired settings and ride.
Hope its of some assistance to you.
post #5 of 6 (permalink) Old 06-16-2012, 09:06 AM
dallasdon's Avatar
I can almost guarantee you it's the fan. I had the same thing happen on my 09. Kawasaki wants more than $400.00 for a new one but I got one off an 010 for $73.00 on EBay.
'09 Versys -Green
TET'68 Survivor
dallasdon is offline
post #6 of 6 (permalink) Old 06-16-2012, 09:27 AM
Heres a new fan for $217.00 w/Free Shipping. http://www.ebay.com/itm/2006-2012-Ka...#ht_556wt_1165
Heres a bunch of used ones cheap.... http://www.ebay.com/sch/i.html?_nkw=...+fan&_osacat=0
