Big clunk going into first gear - Kawasaki Versys Forum
post #1 of 22 (permalink) Old 10-26-2008, 04:19 PM Thread Starter
Just wondering if others notice that when shifting from neutral into first gear that there is a pretty big clunk. It is much harder than other bikes I have owned. The clutch is adjusted properly and all there is no other problems with any other shifting.
brian_nbmc is offline
post #2 of 22 (permalink) Old 10-26-2008, 04:51 PM
toocanad's Avatar
This is my second Kawi. The first gear clunk seems to be a Kawi feature.
toocanad is offline
post #3 of 22 (permalink) Old 10-26-2008, 04:54 PM
JehanQuadi's Avatar
Yup, clunk is normal according to several kawi owners I spoke to as well.
JehanQuadi is offline
post #4 of 22 (permalink) Old 10-26-2008, 04:58 PM
versysred's Avatar
Try just about any BMW has a REAL clunk into 1st gear. My Versys does have a small Clunk
versysred is offline
post #5 of 22 (permalink) Old 10-26-2008, 05:06 PM Thread Starter
Thanks, Just didn't want to think it was mine alone
post #6 of 22 (permalink) Old 10-26-2008, 08:21 PM
blipco's Avatar
Big Kawi fan here. Try holding the clutch in for a few more seconds than normal before selecting first gear from neutral to allow the clutch to settle down (ten secs.) and see if that helps. It works on my ZRX which will clunk you off the back of the bike if you're not ready for it. Still does it after 48,000 miles. (love that bike)
blipco is offline
post #7 of 22 (permalink) Old 10-26-2008, 08:57 PM
Ocean's Avatar
+1
My V shifts into 1st rather smoothly. Compared to my BMW which felt like I was dropping the tranny out the bottom - it's refreshing.
Ocean is offline
post #8 of 22 (permalink) Old 10-26-2008, 10:14 PM
versysred's Avatar
AMS oil get it and forget about CLUNKS
post #9 of 22 (permalink) Old 10-27-2008, 07:18 PM
handkphil's Avatar
Kawasaki Krunch
My '01 Kawasaki ZR-7S made a very distinct, crunchy clunk when shifting into 1st gear. I thought it was a bit loud, but during the time I owned that bike I came across several articles that mentioned this "clunk", and stated that it was practically a Kawasaki trademark. My Versys clunks when shifting into
1st, but only about half as violently as my ZR-7S.
I think Kawasaki should refer to this feature as a "Positive First Gear Finder".
HandKPhil
handkphil is offline
post #10 of 22 (permalink) Old 10-29-2008, 01:18 PM
My "chunk" got better with mileage. Up to 5800kms now.
dmaure is offline
post #11 of 22 (permalink) Old 10-29-2008, 07:04 PM
Check your drive chain tension. Mine clunks only when the chain is slack.
post #12 of 22 (permalink) Old 10-30-2008, 07:03 AM
My Versys does it and my KLR 250 did it as well. Evidently it's got something to do with the wet clutch setup.
ozyran is offline
post #13 of 22 (permalink) Old 10-31-2008, 04:58 PM
The faster you're going when you switch into lower gears, the heavier and louder the "clunk" will be. At a dead stop, dropping into first is more like a snick, dropping into 1st at 40mph is massive clunk, if rpms are not matched, that is. Match rpms and it should be far less noticable.
Motodevil is offline
post #14 of 22 (permalink) Old 10-31-2008, 06:35 PM
handkphil's Avatar
The clunk defined
The clunk I'm talking about is the one you hear when you shift from neutral to first, like when you're stopped at a traffic light that's about to turn green for you. Mine is loud enough that it startles people sitting in cars next to me at the traffic light.
HandKPhil
post #15 of 22 (permalink) Old 10-31-2008, 09:43 PM
blipco's Avatar
Did you try holding the clutch in for about ten seconds before hitting first gear ?
blipco is offline
post #16 of 22 (permalink) Old 11-01-2008, 04:39 AM
handkphil's Avatar
Nope. When I'm coming up to a red light I'm decelerating, braking and downshifting. If I'm lucky I can catch neutral on the way down, just as I'm coming to a stop, but often I have to go all the way down to first and then back up to neutral.
Now I'm stopped and in neutral. If there's no traffic behind me, I'll take the opportunity to stretch, unzip my jacket, etc. As I anticipate the light changing to green I'll pull the clutch all the way in and shift into first, but never without the loud clunk. Doesn't matter if I've held the clutch in for two seconds or ten.
Sometimes you're caught at the light for 25 seconds before it changes, and sometimes you're only there for 5 seconds, depending on when you rolled up. Even if holding the clutch in for ten seconds prior to shifting into 1st was the cure to the clunk, I'm not sure I'd bother. A person doesn't always have 10 seconds to hold in the clutch before shifting into first. Even if I did have ten seconds every time, I'm not sure I'd want to bother shifting into neutral if I still had to hold the clutch in through the majority of the time I was stopped at a red light. If I was going to do that every time I'd just downshift all the way into first gear as I was slowing for the light, and hold in the clutch for the entire duration of the red light.
HandKPhil
post #17 of 22 (permalink) Old 11-01-2008, 07:24 AM
StonedGP's Avatar
The clunk got much better after switching to full synthetic oil (3500 miles). I had an old 1983 GPZ-750 that had a scary loud clunk. Never ever went away fully, but got way better after 5000 miles. Like others have said, "a Kaw trademark".
StonedGP is offline
post #18 of 22 (permalink) Old 11-01-2008, 07:39 PM
hacktracker's Avatar
Even my sweet-shifting Suzuki clunks into first gear.
No worries, you certainly know when it's in gear.
Don
"ride more, worry less"
2000 Honda VFR800 - Street
hacktracker is offline
post #19 of 22 (permalink) Old 11-03-2008, 06:52 PM
redline's Avatar
I agree, I think they all do it to a certain extent. It is not bothersome at all, since most of my past Kawi's {ZRX1100, ZX9R, ZX12R} did it too. Make sure your idle speed is within spec, preferably at the low end....the lower the idle speed, the less pronounced the clunk........
redline is offline
post #20 of 22 (permalink) Old 11-06-2008, 10:05 AM
picjet's Avatar
I too have had shifting issues and have been trying everything to find the sweet spot. I'm installing heated grips on my V and took the plastic off the front and notice that my clutch cable had a kink in it and was bound up in the headlight bracket. I have not had a chance to try it out since I found the problem, I'm hoping it will work alot smoother.
picjet is offline
Similar Threads
Winter/Rain Gear versysred Rider's Gear 21 11-18-2008 09:17 PM
aerostitch or first gear Dross Rider's Gear 17 10-31-2008 06:50 PM
Wear. Your. Gear. ozyran General Discussions - V-650 43 09-27-2008 10:01 AM
Weatherproof Laptop Gear Grow Rider's Gear 5 09-12-2008 11:32 AM
