OEM electrical connectors - Kawasaki Versys Forum
Like Tree1Likes
  • 1 Post By Doug Just Doug
post #1 of 9 (permalink) Old 04-01-2012, 10:05 AM Thread Starter
Does anyone know of a source for the OEM type electrical connectors.
Specifically I need the male ends for the turn signals, because I have some turn signals on the panier rack, that I am installing, that I want to plug in.
Brian
versysxxx is offline
post #2 of 9 (permalink) Old 04-01-2012, 11:50 AM
Eastern Beaver may have what you need.
dirtha is offline
post #3 of 9 (permalink) Old 04-01-2012, 12:11 PM
chid's Avatar
yes, they are Sumitomo .050 connectors from Eastern Beaver.
I bought them and use them.
Versys 2015 Green
chid is offline
post #4 of 9 (permalink) Old 04-01-2012, 02:30 PM Thread Starter
Yes, Yes that is what I need. Thanks much
Brian
post #5 of 9 (permalink) Old 01-30-2019, 04:00 PM
Skyhogg's Avatar
How about the connectors on a 2016 650? I want to make a jumper between the tail light and the harness so I can splice in an LED bar on my license plate with tail/brake lights without cutting into the existing wires. I could do that but I hate cutting wires if I don't have to, so I need the specific male and female connector to make this happen. There's just too many possibilities by simply looking at online pictures. Does anyone know the actual connector used?
Skyhogg is offline
post #6 of 9 (permalink) Old 01-31-2019, 09:42 AM
Doug Just Doug's Avatar
I'm no help with the connector question, but I recently wired up a set of Hyperlites on my Gen 3 using Posi-Locks. Very easy to use and might be the best option next to solder. I don't like cutting into the factory wiring, either, but at least Posi-Locks make me confident nothing is going to vibrate loose or short-out.
quexpress likes this.
2015 Versys 650 ABS
AMA, Retreads Int'l.
Doug Just Doug is offline
post #7 of 9 (permalink) Old 01-31-2019, 11:39 AM
How about the connectors on a 2016 650? ....
Here's what I did on my '15 to add some brake-lights that won't be "blocked" by my camping gear.
ID:	160755   Click image for larger version
ID:	160757   Click image for larger version
ID:	160759   Click image for larger version
ID:	160761   Click image for larger version
ID:	160765   Click image for larger version
ID:	160767   Click image for larger version
ID:	160769   Click image for larger version
ID:	160771   Click image for larger version
post #8 of 9 (permalink) Old 01-31-2019, 12:28 PM
Rokas Mažeika's Avatar
Ive been buying sumitomo mt09 2-3-4-6 pin connectors. 2 pin ones are standard to connect front auxiliary lights
Rokas Mažeika is offline
post #9 of 9 (permalink) Old 01-31-2019, 03:31 PM
chid's Avatar
I think for the rear light the connector is 3 Position .090 Waterproof MT Connector
SM-MT
Versys 2015 Green
chid is offline
