Should I remap - Kawasaki Versys Forum
post #1 of 7 (permalink) Old 03-21-2012, 07:02 PM Thread Starter
glowcat13's Avatar
Should I remap
I had added the arrow slip on a few years back and I didn't remap it at all. This year I am adding the bmc high flow air filter, should I do a remap with the combination of the arrow and bmc filter or should I be fine as is?
Those who say money can't buy happines haven't bought A VERSYS.
glowcat13 is offline
post #2 of 7 (permalink) Old 03-21-2012, 07:11 PM
I had a Yoshi on. Didn't remap it. Put a BMC filter on when i changed out my plugs late last year. Didn't re-map and have had no issues at all. If you go with the BMC filter get a small bottle Of Loc-Tite 406 you'll need it to attach the gasket to the filter. Get the smallest Loc-tite it doesn't take much
post #3 of 7 (permalink) Old 03-21-2012, 07:12 PM
BTW Riders Discount had the best price on the BMC filter with our forum discount
post #4 of 7 (permalink) Old 03-22-2012, 09:38 AM Thread Starter
glowcat13's Avatar
Thanks for the input weljo
post #5 of 7 (permalink) Old 03-22-2012, 12:53 PM
Anytime..
post #6 of 7 (permalink) Old 03-22-2012, 11:07 PM
2daMax's Avatar
Remap is needed only if your top end has reduced, and that is if you are always running at top speed.
Previous Ride:
My V's Farkle Log:
2daMax is offline
post #7 of 7 (permalink) Old 03-22-2012, 11:55 PM
Do you have a Dynojet Power Commander? Stock ECU cannot be remapped, and it's not needed anyway with high flow exhaust and air filter... You can however rotate you main throttle sensor counterclockwise a tad, to have its output voltage at near maximum spec, instead of just below minimum spec range to add fuel from idle to 2800+ rpm where it's most lacking, even with original filter and exhaust.
