Deeper under-seat compartment - Kawasaki Versys Forum
post #1 of 7 (permalink) Old 02-22-2012, 10:34 AM Thread Starter
I'm considering chopping the stock under-tray and adding a deeper compartment made from aluminium or fiberglass.
Something like: This
I already cut the (unnecessary) plastic brackets and bits to get more room for tools but it would be useful to have more storage space
I tried to remove the entire under tray for inspection, but stopped when I saw that ECU and top-box brackets had to be removed. So I think only the first part should be cut and rest left in place.
Does anyone see any adverse effects of this? All suggestions welcomed.
Ivan V is offline
post #2 of 7 (permalink) Old 02-22-2012, 03:03 PM
I like it. You first.
George
bicyclist is offline
post #3 of 7 (permalink) Old 02-22-2012, 03:24 PM
I like it to, great place for my pistol ( just kidding Ivan ).
post #4 of 7 (permalink) Old 02-22-2012, 03:28 PM
post #5 of 7 (permalink) Old 02-22-2012, 03:30 PM
Interesting. That space is already occupied by my Fuzeblock, but more space is better.
Will it be out of the elements? Any chance water will get in?
[SIZE="1"]Ride. Good.
2019 F750GS
2014 R1200RT
2008 Versys (SOLD 11/19)
2003 ST1300ABS (SOLD 5/15)
post #6 of 7 (permalink) Old 02-22-2012, 04:55 PM
Before you do it, I suggest you somehow remove your rear shock's spring, then see how close the rear tire gets to that place at FULL compression. (I see that curved part and figure it was put in there for SOME reason!)
post #7 of 7 (permalink) Old 02-22-2012, 05:49 PM Thread Starter
Well, without the spring it would sink quite low.
I thought about that curved part, but if bottoming of the shock happens it's not going to make any difference. Also, Versys shares parts with ER6 (witch I expect has less clearance) so maybe that's why is there.
Distance from the tire to the plastic is 16cm. I'd be satisfied if I could get an inch of depth for the tray.
Safe clearance from the tire is first consideration.
I'm also unsure about the side mounting options. Maybe curved aluminium over the frame then screwed into the frame?
Bones,
In my mind, it wouldn't be any different from stock as far as water is concerned. Seat and seat plastic trims cover this area pretty well so gun powered will be dry.
Ivan V is offline
