Cranks Doesn't Run - Kawasaki Versys Forum
post #1 of 5 (permalink) Old 02-14-2012, 08:14 PM Thread Starter
Cranks Doesn't Run
Went on vacation for a week, the temp dropped, and the bike wont run. It started for about two seconds only, then the battery died. Still no luck after getting a battery charger; it cranks over only. The fl light comes on a bit. The gas has stabilizer in it. Any suggestions?
pierre522 is offline
post #2 of 5 (permalink) Old 02-14-2012, 08:55 PM
Well if the battery isn't shot. Try cracking open the throttle slightly then hit the start button. For awhile now thats how i have to start mine. If i don't open the throttle up it just trys to crank.
post #3 of 5 (permalink) Old 02-14-2012, 09:20 PM
Have you done any work or maintenance to it lately, or have you installed crash bars or something?
You can retrieve the FI trouble code set in memory.
post #4 of 5 (permalink) Old 02-15-2012, 06:05 PM Thread Starter
Cranking Reply
Thanks, will do the throttle trick. Started to look around at the wiring harnesses and found a cannon plug disconnected on the right side of the bike just under the seat. Still cranking not running though. Will have to wait until the battery recharges now.
post #5 of 5 (permalink) Old 02-15-2012, 07:33 PM
2daMax's Avatar
When you turn the key to On position, do you hear the sound of the fuel pump? It sounds like 'wheeeee'?
Previous Ride:
My V's Farkle Log:
2daMax is offline
