Sticky Shifter - Kawasaki Versys Forum
post #1 of 29 (permalink) Old 01-21-2012, 10:12 AM Thread Starter
Sticky Shifter
I have had an issue lately with down shifting. As I come to a stop, occasionally, but happening more and more, I can not work my way down the gears because the shifter fails to reset unless I release the clutch a little. I intially thought I had not allowed the shifter to spring back up to reset, but I have since ensured this is not the case. Is this a matter of needing to lube the shifter, or is this caused by something else? I ride a 2011 V I bought brand new in September.
jagrugger is offline
post #2 of 29 (permalink) Old 01-21-2012, 11:40 AM
It might need lubing. Left footpeg has to be removed from mounting plate to properly clean and grease the shifter lever's sealed main pivot. You can also grease the two small rod-end links.
Squirting some chain lube on the main link sides may help for now as a quick fix.
post #3 of 29 (permalink) Old 01-25-2012, 03:47 PM Thread Starter
I was paying a little more attention to this, and it seems that when this happens and I have to release the clutch I can feel it catch or engage in the transmission. Shouldn't the gears engage upon depressing the shifter. I am wondering if I need to adjust the clutch?
post #4 of 29 (permalink) Old 01-25-2012, 03:56 PM
If you are having trouble going from 6th to 1st, for example, without letting the clutch out between shifts, then I know what you are talking about. Letting the clutch out with each downshift is the way to go. What (I think) you are describing is normal for a motorcycle transmission - at least on any motorcycle I've ridden.
Mt. Versuvius is offline
post #5 of 29 (permalink) Old 01-25-2012, 04:15 PM Thread Starter
I am a new rider so maybe I am doing it wrong, but what I usually do is coast down to a stop. Usually I engage the clutch and down shift as I slow down but not releasing the clutch in between gears. Usually it catches, but occasionally it gets stuck in one gear until I relase the clutch. If i don't need the gear (for instance the light is still red so I keep coasting) and I have slowed even more I down shift again. Obviously as I am coasting down and down shifting IF a quicker stop is needed I will engage the clutch to engine brake and shorten the stopping distance. As far as I knew you should be able to shift through the gear range with out releasing the clutch. I even tried pushing up on the lever to reset it but it did not work.
post #6 of 29 (permalink) Old 01-25-2012, 04:35 PM
I always downshift and use engine braking with every gear except maybe 2nd & 1st sometimes.
Every MC I have ridden or owned does not like to be cruising in 5th or 6th, pull in the clutch and stop with brakes only and then just click down the shifter back to 1st. Sometimes you can get away with it, but usually have to release the clutch some on the way down.
I believe this is more about operator than equipment.
post #7 of 29 (permalink) Old 01-25-2012, 06:14 PM Thread Starter
Still researching this, maybe my riding habits need a tweak.
post #8 of 29 (permalink) Old 01-25-2012, 07:16 PM Thread Starter
Well I will be tweaking my shifting habits, but there is no way you can shift accoriding to the parameters set in the owners manual!!
post #9 of 29 (permalink) Old 01-25-2012, 07:26 PM Thread Starter
Oh and thanks for the help!!
post #10 of 29 (permalink) Old 01-25-2012, 07:38 PM
How's your clutch cable slack? You can also adjust lever distance from the bar with the numbered wheel. Have you lubed your clutch cable, and is your normal idle set to 1300 rpm? Proper drive chain slack also makes a difference. How old is your oil? Synthetic JASO MA oil helps as well.
post #11 of 29 (permalink) Old 01-25-2012, 07:47 PM
I could not tell you what the manual says. I shift up and down based on sound & feel and my goals for the moment. She will let you know if your not doing something right! Be careful as you are learning the downshift as the Versys can bark the rear tire if you pop the clutch downshifting too fast without giving enough throttle.
post #12 of 29 (permalink) Old 01-25-2012, 07:47 PM
Down shifting while in motion is better than shifting through the gears when you are stationary. Try shifting when in motion and this will let the engine brake before coming to a standstill and by this time you will be in 2nd and shifting down to 1st should not be a problem.
If you are in 6th when stationary, then shifting all the way down to 1st, you will need to release the clutch a little.
Keep all joints and links oiled will help smooth shifting too.
You problem seem to more on riding habit.
Fastoman is online now
post #13 of 29 (permalink) Old 01-25-2012, 08:53 PM
I was thinking clutch cable slack as well. Easy to overlook, and easy to adjust.
post #14 of 29 (permalink) Old 01-25-2012, 08:53 PM Thread Starter
The slack looked good. I have not lubed it and it might be a good idea to do so anyway, its been smooth but preventative measures are the best. Idle is good, as well as the chain slack. The oil is fairly new as I just changed it just over 3000 miles, i am almost at 4000 now. I have been holding off on switching to synthetic for a little bit.
Yeah came across their shifting table researching this. I don't think shifting to 6 gear at 34 mph would work out well
Yup was talking with a friend and did remember it seemed to happen more when I was slower. So and adjustment to my riding habit will commence tomorrow.
post #15 of 29 (permalink) Old 01-25-2012, 09:06 PM
There should also be 2-3 mm of throttle grip free play for better control. Lubing throttle tube and cables can help too... You can easily pull the mid-cable adjuster that runs over the engine, adjust it then check with cable back up in its natural position. Shown here with locknut loosened and backed up to the right:
post #16 of 29 (permalink) Old 01-26-2012, 01:25 AM
pizellu's Avatar
Downshift
Hi Jagrugger,
You should always downshift while in motion, 1 so as to use the engine brakes as much as possible, and 2 when you are stopped you won't need to fiddle with gears to shift to 1st cause you'd already be in 1st.....If you'd live in a country like i do where the tarmac is like polished cement you would never rely only on the brakes cause it's too slippery.
Practise this as much as possible especially if your bike has not got ABS.
Apart from that all the bikes I owned won't shift from top gear to 1st when stopped.
pizellu is offline
post #17 of 29 (permalink) Old 01-26-2012, 04:33 AM
"Research has shown" that the quickest way to stop a motorcycle is with the clutch in and only using the brakes, and even then, mainly the front brake. But in normal circumstances you're not looking for the quickest way to stop but the smoothest and safest. Keeping the bike in the proper gear relative to road speed, using some engine braking, is the safest technique. It gives you more options for accident avoidance if you need to get back on the throttle in a hurry.
post #18 of 29 (permalink) Old 01-26-2012, 08:59 AM
blipco's Avatar
+1. The rear brake stops the bike with more control and stronger than any engine. Less wear on the engine as well. Engine braking can also be unpredictable. Front brakes do the most effective braking.
blipco is offline
post #19 of 29 (permalink) Old 01-26-2012, 04:00 PM
blipco, I actually was advocating the use of engine braking, except in an emergency stop situation. It resolves the issue the OP raised, as well as putting you in the correct gear in case of trouble.
post #20 of 29 (permalink) Old 01-26-2012, 04:11 PM
The OP is talking about everyday riding, not emergency braking. Every single rider I know uses engine braking during decel. I am not concerned with added wear to the engine. I would think without engine braking, one would wear the brake pads a rotors much faster.
Side note: I ride with one lady who uses only her rear brake! We have discussed this and I see that she always rides in front of me. I hope one day she does not need the full potential of both brakes in an emergency.
