Which Low Beam wire for HID trigger? - Kawasaki Versys Forum
post #1 of 5 (permalink) Old 01-10-2012, 02:28 PM Thread Starter
Pretbek's Avatar
I want to trigger the relay for my HID aux lights off of the low beam, so that they will only come on when the low beam is on (after starting the engine).
Does it matter which wire should I tap into, the Blue-Yellow, or the Black-Yellow?
Pretbek is offline
post #2 of 5 (permalink) Old 01-10-2012, 03:31 PM
chid's Avatar
Do you have a switch to activate them?
If you have it, you can get any wire that is ON with the contact, not only the low beam.
but you have to connect directly to the battery with a 15A fuse for the HID.
Versys 2015 Green
chid is online now
post #3 of 5 (permalink) Old 01-10-2012, 03:48 PM
Black-yellow is ground. Blue-yellow is battery. If you're triggering a relay, you want to do it with battery.
George
bicyclist is offline
post #4 of 5 (permalink) Old 01-10-2012, 04:04 PM Thread Starter
Pretbek's Avatar
Thanks both, that answers my question.
It will have a switch as well chid, but I chose the low beam because that is only on after starting, when the engine is running.
If I connect the HID to any wire that is ON with the contact, it will probably momentarily switch off during the engine starting process. This on-off-on behavior is not much appreciated by HID setups and will quickly kill the ballast/igniter.
Pretbek is offline
post #5 of 5 (permalink) Old 01-10-2012, 05:11 PM
chid's Avatar
I know, I have a dual bi-xenon setup.
right now I'm only using one projector but I want to wire the second one with a switch and a relay, using it as a back up, the light from one projector is really enough..
The one that is running now is connected using the original wires and has no problem with the delay start from the system.
Versys 2015 Green
chid is online now
