*emergency* question about busted bottom engine - Kawasaki Versys Forum
post #1 of 43 (permalink) Old 01-10-2012, 12:42 PM Thread Starter
BAMF's Avatar
today I came off a higher (than I thought) curb and my exhaust bottomed out on the curb. The two brothers exhaust VALE system stayed intact with just a minor dent on the pipe, but the bolt that tightens the exhaust to the header seems to have popped open some sort of plug and oil came gushing out all over the road.
I am fine, the bike is fine. Sea horse cases and sw motech rack took the super slow-mo fall just fine! I just wanna know what this is?? It is somewhat at the back near where you let the engine oil drain out of. It looks like a halfdollar size metal chuck/coin that has been dislodged. It does not look like anything actually cracked.
I need to know what this "plug" is so that I can assess the damage and decide if it is something I can just fix myself or if its something catastrophic that I need to call the insurance about and get it taken to a dealership. I honestly think the bolt was not supposed to be on "top" of the pipe which is what caused it to hit that specific part of the engine.
Lemme know if you guys have any ideas...
1997 KLR 650
2011 Halle-friggin-leuya Versys
BAMF is offline
post #2 of 43 (permalink) Old 01-10-2012, 12:48 PM Thread Starter
BAMF's Avatar
if you have a stock exhaust this part of the engine is probably going to be hard to see BTW
1997 KLR 650
BAMF is offline
post #3 of 43 (permalink) Old 01-10-2012, 01:00 PM
mchieffallo's Avatar
Sorry for your mishap BAMF. Glad you're not hurt. I'm at work and don't have access to my bike, but I suggest checking your owners manual. I think I know what part your talking about. The first time I changed my oil on the V, I mistakenly thought it was the drain plug. If you need replacement of the part, Bike Bandit has very good schematics to find what you need. Good luck.
Dark Arrow Slip-On Exhaust, Spencer's Seat, Alaskan Sheepskin Buttpad, Givi Windshield, Givi E460 Topcase, SW Motech Crashbars, SW Motech Alu-Rack, Cortech Sport Soft Saddlebags/Tailbag, 16T Front Sprocket, Kawasaki Z-1000 Mirrors, Speedy's Handlebar Riser, Speedy's FlatFoot, MFW Highway Pegs, Gerbings Heated Gloves
mchieffallo is offline
post #4 of 43 (permalink) Old 01-10-2012, 01:13 PM
El Tig's Avatar
Don't know what to tell you except good luck! Can you take quick picture for one of the experts to have an idea where it is?
I almost had the same thing happen when I went off a curb in front of the GF...standing up on pegs, picking my line, scrapping the exhaust.....
El Tig is offline
post #5 of 43 (permalink) Old 01-10-2012, 01:18 PM Thread Starter
BAMF's Avatar
good idea about the schematic on bike bandit...that might be the key!
okay I looked it up, and i think it is here http://www.bikebandit.com/houseofmot...20269sch706759
and the number is 92066B... it is just a plug...i think it is catagorized by "freeze plug"
1997 KLR 650
BAMF is offline
post #6 of 43 (permalink) Old 01-10-2012, 01:43 PM
offcamber's Avatar
Freeze plug is what I was going to say it probably is..
" I don't care about shinny chrome or loud exhaust, I don't ride to be seen, I ride because I want to disappear"
Halfthrottle
offcamber is offline
post #7 of 43 (permalink) Old 01-10-2012, 01:46 PM Thread Starter
BAMF's Avatar
so... is this a matter of just pressing it back in?
1997 KLR 650
BAMF is offline
post #8 of 43 (permalink) Old 01-10-2012, 03:15 PM
Soryy about that BAMF! I'm not sure you might have to call Kawi service! I'll be watching to see how that is fixed?
post #9 of 43 (permalink) Old 01-10-2012, 05:18 PM Thread Starter
BAMF's Avatar
got it up on the stand at home, it is NOT the freeze plug. It is an oddly uniform hole punched out of my oil pan by the two brothers vale tension strap thingy. So I will be looking for the best deal on the OEM oil pan for the 2011 kawasaki versys.
1997 KLR 650
BAMF is offline
post #10 of 43 (permalink) Old 01-10-2012, 07:17 PM
Baron650's Avatar
Oh Bummer!
Baron650 is offline
post #11 of 43 (permalink) Old 01-10-2012, 07:31 PM
Sorry to hear about your mishap. I know others are thinking this, "What were you doing riding on the sidewalk?".
post #12 of 43 (permalink) Old 01-10-2012, 08:40 PM Thread Starter
BAMF's Avatar
lol wasn't riding on the sidewalk, there are tons of places to park your bike in philly that are on sidewalks and up against buildings. I was simply pulling out of one of those.
Bike bandit gave me a new oil pan for about $95.
So the important news is to make sure if you have a slip on exhaust, make sure the bolt to the tension ring/strap that fastens your slip on to the header IS NOT on top. This is what caused my damage. Amazingly, the exhaust was hardly dented but was able to punch a hole in the oil pan.
1997 KLR 650
BAMF is offline
post #13 of 43 (permalink) Old 01-10-2012, 08:44 PM
2daMax's Avatar
The part says 25X5, probably 25mm diameter plug x 5mm thick. It is not threaded and probably pressed fit to seal up the hole that was meant to do something of which only Kawa designers know about.
If you know of a machine shop, they maybe able to help to press fit that thing back. I've seen such process being done. The bore part is heated up while the plug is frozen up. Parts are brought together and hammered. It takes a great deal of energy to pop it up open, so chances is that the engine part has a localized warpage near the plug hole.
Previous Ride:
My V's Farkle Log:
2daMax is offline
post #14 of 43 (permalink) Old 01-10-2012, 08:55 PM
blipco's Avatar
Don't forget, the plug is still inside the engine. Not good.
If that plug is part of the oil pan and not the lower case, make sure the plug comes installed if you buy a new pan (provided the pan itself is not damaged). If not, just buy a new plug. You will have to take the pan off to remove the old plug from the engine anyway. Before you buy anything, give it a good look-see first. Don't forget gaskets. Good luck and keep us informed.
blipco is offline
post #15 of 43 (permalink) Old 01-10-2012, 09:18 PM
As BAMF mentioned, it's not the crankcase plug after all. He punched a hole in his cast aluminum oil pan... Freeze plugs are for coolant, by the way.
http://www.ebay.com/sch/i.html?_trks...l+pan&_sacat=0
http://www.ebay.com/sch/i.html?_nkw=....c0.m270.l1313
More oil pans! http://www.ebay.com/sch/i.html?_nkw=....c0.m270.l1313
post #16 of 43 (permalink) Old 01-10-2012, 09:28 PM
•Replace the oil pan gasket with a new one.
•When installing the oil pan, align the damper on the breather pipe with the hollow on the oil pan.
•Tighten:
Torque - Oil Pan Bolts: 12 Nm (1.2 kgfm, 106 inlb) [8.83 ftlb]
Oil pan gasket # 11061-0167 Retail $9.84, $6.84 from: http://www.partshark.com/fiche_secti...010&fveh=38807
post #17 of 43 (permalink) Old 01-11-2012, 12:15 PM Thread Starter
BAMF's Avatar
omg invader if you were a woman I would kiss you in the MOUTH!
They were having to backorder from thailand so i was going to have to go without my V for TWO FRIGGIN WEEKS! that is unacceptable because I ride year round, bout 2500 miles per month.
yea so a note to all V users with a slip on exhaust. DO NOT have the bolt for the tension mechanism on top, because it will puncture the engine if you bottom out.
*its a good thing I caught this because I will have to make sure I have the SW Motech engine skip plate thing, and I might have to modify it to extend further down the crankcase. I do plan on fully using this motorcycle and a curb is not going to be what brings me down.
once again, THANK YOU INVADER
1997 KLR 650
BAMF is offline
post #18 of 43 (permalink) Old 01-11-2012, 05:15 PM
BAMF - DON'T throw the old oil pan away! Take it to a welder and get it fixed, then either have it as a spare, or see who else needs one.
post #19 of 43 (permalink) Old 01-11-2012, 05:58 PM
Been there, done that, have the t shirt. look left of the hose...........
Mountain Man is offline
post #20 of 43 (permalink) Old 01-11-2012, 07:08 PM Thread Starter
BAMF's Avatar
I think it is past the point of easy repair, but I will see what can be done. Is our engine aluminum or that crappy aluminum "pot metal" that older asian bikes were made of? That could make the difference.
1997 KLR 650
BAMF is offline
