Tank removal - Kawasaki Versys Forum
post #1 of 6 (permalink) Old 12-12-2011, 02:48 PM Thread Starter
pizellu's Avatar
Tank removal
Hi there, just getting my way to my recently bought Versys. Question Is it true you need to take off the gas from the tank to dismount?? Is there a stopcock or something similar?
Thanks for all your help!!!
pizellu is offline
post #2 of 6 (permalink) Old 12-12-2011, 04:41 PM
Lonerider's Avatar
You do not have to remove the petrol from the tank when you want to remove it.
rgs
Lonerider is offline
post #3 of 6 (permalink) Old 12-12-2011, 05:23 PM
There is no stop-**** for the fuel tank. It's easier to siphon out most of the fuel so you don't have to manage the extra weight. For changing spark plugs, cleaning the intake-air filter, you can just raise the tank enough to do the job (tie it up, turn it and set it on a bench) without complete removal and disconnecting the various lines.
ScottyNeal is offline
post #4 of 6 (permalink) Old 12-12-2011, 05:35 PM
I just unhooked the 2 lines and sat the tank over the seat area and strapped it to the bike.
IMG_0557 by weljo2001, on Flickr
post #5 of 6 (permalink) Old 12-12-2011, 06:22 PM
I've disconnected all the lines and removed the tank a few times. For me, it's important to have less fuel in it to reduce its weight. Some listers are rather intimidated in removing the fuel line, because - do it wrong and you break the fitting. If you read up on how it's done a few times before doing it, it'll become relatively simple.
Don't do it from this post - READ the manual. What you do is pull back a 'gate' that locks the fitting by using a slot screwdriver (around 1/4" blade) that JUST fits. Insert it, then turn it 90 degrees aprox. and the gate moves out and the fitting is apart. Wrap a rag around it as it WILL leak some gas once it's apart.
post #6 of 6 (permalink) Old 12-13-2011, 03:45 PM
Velocibiker's Avatar
No, you don't have to drain the tank to remove it. It just makes moving it around easier. The fuel line is super easy to release. Plus - everything is easier with the tank off and safely away from the bike. You don't have to worry about dinging it with a tool or accidently having it drop to the ground.
Velocibiker is offline
