quick Q`- break peg - Kawasaki Versys Forum
post #1 of 8 (permalink) Old 12-12-2011, 10:53 AM Thread Starter
katangilis's Avatar
quick Q`- break peg
Hi All
my rear break peg ( or "leg lever") is sinking way too low
is this lever can be adjust ,to start breaking from a higher point ?
the break oil level is ok...
katangilis is offline
post #2 of 8 (permalink) Old 12-12-2011, 06:38 PM
I believe there's mention in your owners manual. However, if you can't find it, go to here:
http://motowerk.com/loweringfootpegsblocks.aspx
and read it all, especially the instructions as they'll tell how to adjust your brake lever.
post #3 of 8 (permalink) Old 12-12-2011, 07:38 PM
Baron650's Avatar
Check your brake pads. This may indicate it is time to replace them.
Baron650 is offline
post #4 of 8 (permalink) Old 12-12-2011, 08:33 PM
Turning out the brake peg to your liking with a pipe wrench can also give you a better brake feel once you have the vertical clearance solved.
post #5 of 8 (permalink) Old 12-13-2011, 03:00 AM Thread Starter
katangilis's Avatar
10x fasteddiecopeman
regarding the link , i do not want to get the right peg lower ,i want the rear break pedal to start break "higher" or "sooner"
post #6 of 8 (permalink) Old 12-13-2011, 04:45 AM
The brake pedal is adjustable, but the mechanism is a bit of a bugger to get at. You have to remove the footpeg hanging bracket to get at the locknut. Once adjusted, double-check that your brake light activates properly when you push on the brake pedal. When I adjusted my pedal downwards the brake light was on all the time - had to fiddle with the spring a little bit to get it to turn off.
Mt. Versuvius is offline
post #7 of 8 (permalink) Old 12-13-2011, 05:27 AM
I adjusted my pedal UP with the linkage. I did not take anything apart, just loosened the jam nuts on the adjuster rod. Once I had the pedal where I wanted it, I adjusted the brake light switch like in the owners manual. If you change the pedal adjustment, you have to change the light adjustment.
David
David RSparky3 is offline
post #8 of 8 (permalink) Old 12-13-2011, 10:06 AM Thread Starter
katangilis's Avatar
thank you guys
ill try the "don`t take anything apart" method
hope it will work
