Chain adjustment - Kawasaki Versys Forum
post #1 of 6 (permalink) Old 12-10-2011, 08:40 PM Thread Starter
Chain adjustment
Does the Versys need the chain adjusted after installing Speedy's lowering kit?
I installed the kit today and now my chain seems to be a little tight. Thanks
Bandit is offline
post #2 of 6 (permalink) Old 12-10-2011, 09:03 PM
Frisco's Avatar
If your chain is not adjusted properly, you should adjust it, lowering kit or not.
CJ
Frisco is offline
post #3 of 6 (permalink) Old 12-10-2011, 09:15 PM
No...http://www.kawasakiversys.com/forums...ing+kit&page=2
post #4 of 6 (permalink) Old 12-11-2011, 10:04 AM
Baron650's Avatar
Check your chain slack per the manual, and if it needs adjusting then do it.
Baron650 is offline
post #5 of 6 (permalink) Old 12-11-2011, 10:27 AM
My chain was tight after the install. I adjusted per manual.
post #6 of 6 (permalink) Old 12-11-2011, 03:08 PM Thread Starter
I adjusted the chain on the V last night, I think the dealer adjusted it too tight when he set the bike up and when I installed the lowering kit it just seemed like it got a little tighter. I had 28,000 miles on my Bandit 1250 when I sold it and still on the original sprockets and chain and still good for a few thousand miles more. I always ran that chain a little on the loose side and used only gear lube on it.
Bandit is offline
