Anyone else have the headlight socket burn out? - Kawasaki Versys Forum
post #1 of 6 (permalink) Old 11-29-2011, 07:35 PM Thread Starter
Ogre_fl's Avatar
With the commute home now in the dark thanks to the change in daylight savings, I found that my high beam head lamp was out.
Found it out around 6500 miles, but I never rode the Versys after dark before so it could have been sooner.
I was hoping it was a cheap, buy it at the auto parts store item.
Nope, ended up being $58 order from Kawasaki only part
Anyone else have one of these burn up?
Ogre_fl is offline
post #2 of 6 (permalink) Old 11-29-2011, 08:57 PM
2daMax's Avatar
Not mine....but it appears that there was probably a short on that terminal causing some spark or arching (black soot on one terminal). Plastics doesn't seem to have melted, me thinks is some kind of a glass filled Liquid Crystal Polymer (LCP) which has high melting point (300 deg C).
Previous Ride:
My V's Farkle Log:
2daMax is offline
post #3 of 6 (permalink) Old 11-30-2011, 04:21 AM
Daedalus62's Avatar
I had my low beam socket exactly like that... But I was using a cheap lamp (not the EOM), so maybe it was just due to heat build up from a poorly designed/fabricated cheap lamp?!...
Anyway I discarded the socket... I was installing HID xenon when I found this out.
Cheers
Daedalus62 is offline
post #4 of 6 (permalink) Old 11-30-2011, 07:33 AM
Hardware's Avatar
I can’t imagine what that point could have shorted to (although I guess the lamp itself could have shorted internally) ... but a loose/poor connection between the lamp’s blade and the connector could have done it.
Poor connections increase resistance, which creates heat at the point of resistance, which increases resistance, ...
~~ Live Like You're Dying ~~
Hardware is offline
post #5 of 6 (permalink) Old 11-30-2011, 11:13 AM Thread Starter
Ogre_fl's Avatar
The thing that I found very odd is the bulb (the original I believe) was/is fine.
I am still using it.
Do you still have the good one off your highbeam side....I'll give ya $10 for it.
Ogre_fl is offline
post #6 of 6 (permalink) Old 11-30-2011, 02:15 PM
Daedalus62's Avatar
I noticed the same, the lamp was OK (just a little heat discolored near the contact tab) and the socket was melted/burned... Maybe Hardware as a point, poor connection contact...
Sorry buddy, no deal because I need it I only installed HID xenon in the low beam, the high beam is the same.
Cheers
