Rear axle nylon nut - Kawasaki Versys Forum
post #1 of 22 (permalink) Old 11-28-2011, 03:48 PM Thread Starter
Pismocycleguy's Avatar
Rear axle nyloc nut
Anybody know the specifications for the rear axle 18mm nut? Such as pitch, etc?
I would like to replace the rear axle castle nut with a nyloc nut, and discard the cotter pin.
Any suggestions on where to purchase this item?
Pismocycleguy is offline
post #2 of 22 (permalink) Old 11-28-2011, 04:00 PM
'Houston I think we have a problem"
I assume you mean a nylock nut. Get ready for an onslaught.
I bought these for my KLR but lost my tools before my first flat and never got to use them.
A web search provides several other variations.
The stock nut is listed as
42045 NUT,CASTLE,18MM 42045-018
on
http://www.cheapcycleparts.com/model...semblies/41071
cmoreride is offline
post #3 of 22 (permalink) Old 11-28-2011, 04:08 PM
Pretbek's Avatar
You probably won't set the atmosphere on fire if you use a nylock nut but I'm not sure it is a good idea to use that kind of nut in this application.
The nut normally needs to be tightened with 80 ft-lbs of torque I believe. If this is to hold a certain tension on the rear assembly and is not just a safety issue (prevent your rear wheel from falling out), then a nylock nut will not be able to reproduce that tension by a long shot; you will strip out the nylon.
In that case just using a regular nut without a cotter pin to secure it seems like a better solution to me, because I don't think that nut would ever come loose when tightened to 80 ft-lbs, but it will be able to be tightened down with the required torque.
Pretbek is offline
post #4 of 22 (permalink) Old 11-28-2011, 04:16 PM
douglasgraham's Avatar
Yep Id say the use the regular nut and the cotter pin you dont want to take that kind of chance.
douglasgraham is offline
post #5 of 22 (permalink) Old 11-28-2011, 04:23 PM
ROCKER's Avatar
Why??????????
ROCKER is offline
post #6 of 22 (permalink) Old 11-28-2011, 05:06 PM
kenr74's Avatar
Most of my dirtbikes don't use a cotter pin. Not sure why a nylock wouldn't work. I've never had a axle nut back off after proper installation.
1974 Kawasaki F11
2004 Yamaha WR450 plated
2014 Kawasaki Versys 650
kenr74 is offline
post #7 of 22 (permalink) Old 11-28-2011, 05:32 PM
gti20vturbo's Avatar
My CBRs have locking type nuts and no cotter pins. If its good enough for Honda should be OK on a Kawasaki. The Honda nut is not nylon though. Its a crimped metal nut if I remember correctly.
ST1300, Versys, SV650S
gti20vturbo is offline
post #8 of 22 (permalink) Old 11-28-2011, 06:57 PM Thread Starter
Looks like my spelling checker on my iPad over corrected "nyloc" to "nylon"! I'm still getting use to all of the automatic features.
I know that Dual Star offers locking axle nuts for KLR650's, KTM's and Suzuki V-Srroms. So that must have some merit!
I'll keep searching!
post #9 of 22 (permalink) Old 11-28-2011, 10:35 PM
I'm with the guys who say to use the metal lock-nuts, not the "Nylocks". The metal ones are re-usable, and I had a set on my KLR for pretty much EVERYTHING. The local hardware store here in Florence, AZ, sells 'em.
post #10 of 22 (permalink) Old 11-28-2011, 11:18 PM
M18 X 1.5 (fine thread)
post #11 of 22 (permalink) Old 11-28-2011, 11:25 PM Thread Starter
Question BMW Motorcycles
Over the weekend I noticed that the new, chain driven, BMW Motorcycles do not use a cotter key on the rear axle bolt. They all had a nut that looked very much like a nyloc nut. I will do some further research and find out what type of locking nut they are using on their bikes.
The above pictures of a steel lock nut do not look anything like what BMW is using.
“Don’t bother me with DETAILS!”
post #12 of 22 (permalink) Old 11-28-2011, 11:30 PM Thread Starter
Question Pitch of axle threads
I think that the rear axle has a coarse pitch of 2.5?
/Users/johncole/Desktop/Locking_Axle_Nuts.gif
/Users/johncole/Desktop/AXLE_NUTS.JPG
post #13 of 22 (permalink) Old 11-28-2011, 11:43 PM
It is in fact M18 X 1.5 as measured.
Suzuki flanged metal lock nut # 08319-3118A, as used on 2008+ DL650 V-Strom.
(used) http://www.ebay.com/itm/NUT-swing-ar...item518a7057ec
post #14 of 22 (permalink) Old 11-28-2011, 11:45 PM
Motopsycho's Avatar
Just remember nylock nuts are only good once. You need to replace them every time you remove them.
IBA # 49372
Motopsycho is offline
post #15 of 22 (permalink) Old 11-29-2011, 05:39 AM
The old adage applies: If it ain't broke, don't fix it. IMHO
Scottbikes is offline
post #16 of 22 (permalink) Old 11-29-2011, 06:35 PM Thread Starter
Talking Self-locking flanged nut
This is what I am using,
M18 x 1.5p
Saves the hassle of messing with a cotter key and trying to line up the notches in the castle nut. Don't need to keep buying cotter keys.
post #17 of 22 (permalink) Old 11-29-2011, 06:38 PM Thread Starter
Question Why not?
Originally Posted by ROCKER View Post
Why??????????
Because I can and I want to!
Much neater, cleaner, and easier to apply and remove!
post #18 of 22 (permalink) Old 11-29-2011, 06:48 PM
how do they function?
obviously they have some locking mechanism correct?
post #19 of 22 (permalink) Old 11-29-2011, 06:53 PM Thread Starter
Talking
They have a thin steel rim where you would find nylon on a nyloc nut.
It must place tension on the threads.
post #20 of 22 (permalink) Old 11-29-2011, 10:23 PM
IF you're really anal - after you put locknuts on, drop a cotter-pin thru the hole in the unlikely event the nut starts to back-out, which keeps it from departing.
