little advice on backfire - Kawasaki Versys Forum
post #1 of 18 (permalink) Old 11-27-2011, 04:53 PM Thread Starter
jettexas's Avatar
violent back fire and surge when i was rideing today. first of such problem ever. i think it might be the timeing or valve issue or any other thoughts i might check, dont have any time now but will start to braker down in a few weeks. Thanks, jet:feedback
jettexas is offline
post #2 of 18 (permalink) Old 11-27-2011, 09:27 PM
How much mileage on your 08, and when does it backfire exactly? Are you on original spark plugs?
post #3 of 18 (permalink) Old 11-27-2011, 10:44 PM
mine backfires sometimes when i twist the throttle at very low revs
fineout is offline
post #4 of 18 (permalink) Old 11-28-2011, 02:14 AM
Mine did too with aftermarket exhaust, until I adjusted my main throttle sensor (TPS).
post #5 of 18 (permalink) Old 11-28-2011, 03:05 AM
2daMax's Avatar
jettexas, are u on stock exhaust? What actions caused it to back fire (like decceleration, off throttle ?)
Previous Ride:
My V's Farkle Log:
2daMax is offline
post #6 of 18 (permalink) Old 11-28-2011, 06:48 AM
Pretty sudden this backfiring. See if the anything has come loose causing mixture being too lean. Any chance taken bad fuel?
post #7 of 18 (permalink) Old 11-29-2011, 04:23 AM Thread Starter
jettexas's Avatar
about 25k miles maybe 15k on the current set of plugs. seems to happen at random times starting out and at speeds. happend maybe 4 times on a 20 miles ride.
jettexas is offline
post #8 of 18 (permalink) Old 11-29-2011, 05:21 AM
Start by replacing spark plugs, while checking for any vacuum leak. Have you checked your valve lash clearances yet?
post #9 of 18 (permalink) Old 11-29-2011, 01:38 PM
are you twisting the throttle hard at like 1500rpm-2000rpm... that would cause bucking and sputters because you have no power then. but year first sparkplugs... what mods do you have?
skizzo81 is offline
post #10 of 18 (permalink) Old 11-29-2011, 08:49 PM
2daMax's Avatar
sounds like plugs to me.
Previous Ride:
My V's Farkle Log:
2daMax is offline
post #11 of 18 (permalink) Old 12-05-2011, 09:01 PM
Check the exhaust pipes at the head. If the fasteners have backed off, any air leak will cause backfires.
09 Versys
00 KLR
USN 1959-65
ttpete is offline
post #12 of 18 (permalink) Old 12-18-2011, 10:12 AM Thread Starter
jettexas's Avatar
well i have changed the plugs they looked good and cleaned the air filter. seems to be happenning more in slow excelleration. also ran a batch of sea-foam carb and injector cleaner through it. still is happening and maybe a little more. do you think i should have bought a new airfilter? all i did was clean the old one and put it back. but with the change of cleanning the airfilter seems to be happenning more. I checked the timeing and it looks good.
being that the backfire is happenning on excelleration that would lead me to think it is in the intake somewhere. any thoughts on where I might be to check for an intake vacume leak.
thanks
jettexas is offline
post #13 of 18 (permalink) Old 12-18-2011, 10:51 PM
MowDoc's Avatar
Backfiring through the intake or exhaust? If it's intake on acceleration then it's too lean. Could be vacuum leak, low fuel pressure, possibly bad fuel, water, or dirty injector.
Maybe sink the throttle bodies. If it's intake backfire I guess it could have blown the vacuum caps off where you sink them.
I guess it could be the tank isn't venting like it's suppose to.
It is possible that it's ignition. I have seen many coils break down under acceleration in the automotive world but that's more of a dead miss and not so much backfiring.
MowDoc is offline
post #14 of 18 (permalink) Old 12-18-2011, 11:05 PM
thanks
You mean under moderate acceleration? Does it happen more at near 2800 rpm (where the A/F mixture is normally leanest)? Have your tried adjusting your main throttle sensor (TPS)?
Have you adjusted your valve clearances and synchronised your throttle bodies yet?
Do you have an aftermarket exhaust? If so, have you sealed off the PAIR valve?
post #15 of 18 (permalink) Old 12-19-2011, 07:56 AM
Versystole's Avatar
Do you have an aftermartet exhaust? If so, have you sealed off the PAIR valve?
My 2008 V, purchased used, came with a Leo Vince, and I get some occasional backfire on de-accel.
What is the PAIR valve, and how do I seal it off?
Versystole is offline
post #16 of 18 (permalink) Old 12-19-2011, 08:33 AM
The pair valve bleeds air into the exhaust to help the catalyst burn off hydrocarbons. When the cat is removed, it's no longer necessary and it then causes backfires.
Lift the tank, and you'll see a large hose coming out of the airbox. Pull it off the fitting and put something inside to plug it, then put it back on the fitting. Replace tank.
09 Versys
00 KLR
USN 1959-65
ttpete is offline
post #17 of 18 (permalink) Old 12-19-2011, 08:55 AM
Versystole's Avatar
Thanks... I'll do it when i clean the air filter!
post #18 of 18 (permalink) Old 12-19-2011, 09:11 AM Thread Starter
jettexas's Avatar
I'm going to try synchronizing my throttle bodies and adjusting my main throttle sensor when i get time. Thanks for all the advice i will let yall know what the results are.
JET
jettexas is offline
