How do you drain the gas tank? - Kawasaki Versys Forum
post #1 of 2 (permalink) Old 11-25-2011, 10:58 AM Thread Starter
miguelito's Avatar
I just took my tank off to be painted, and ended up draining most of the gas out of the top bung hole into a container. There's still a lot of gas in there which I can't drain this way, ( I suppose due to a baffle system in the tank. So do I just remove the fuel pump and drain it out the bottom? Is that just a matter of disconnecting the bolts fastening it to the tank, or will I need a new gasket after doing so? Any help is greatly appreciated.
Michael
- Terry Pratchett
miguelito is offline
post #2 of 2 (permalink) Old 11-25-2011, 04:26 PM Thread Starter
miguelito's Avatar
that's it, no new gasket required. the pump mount flange is not symmetrical, so the pump can only be reinstalled in one position. do not over tighten the fasteners, they're easy to shear. i use a touch of blue gel. the fuel level sending unit and connector can be taped off, no need to remove it. tape off all the openings so no dust.
very easy, you won't have any problems.
Done and thanks JD!
Michael
- Terry Pratchett
