Erratic Speedometer Read - Kawasaki Versys Forum
post #1 of 3 (permalink) Old 11-12-2011, 12:18 PM Thread Starter
I'm having problems with the speedometer. When traveling between 50 - 60 mph the speedometer is jumping around. Usually jumps 10 - 15 mph higher for a second and back. Noticed it about a week ago and is getting worse. I cleaned the pickup and sprocket area and no difference. Is there a ground or something on the speedometer assembly? Everything else on the instrument cluster is working fine. Its an 08 with 14,000 miles.
Fishnbait is offline
post #2 of 3 (permalink) Old 11-12-2011, 08:21 PM
2daMax's Avatar
Sounds intermittent. Possibility loose wire, and as you may suspect, the grounding cable.
Previous Ride:
My V's Farkle Log:
2daMax is offline
post #3 of 3 (permalink) Old 11-18-2011, 08:33 PM Thread Starter
Had some time to work on the bike. Problem fixed.
Used contact cleaner and dielectric grease on any electrical plug I could get to. Probably a good idea anyway. They all looked clean and tight when disassembled.
Thanks for your support 2daMax.
