Oil filter question - Kawasaki Versys Forum
post #1 of 11 (permalink) Old 10-23-2011, 03:24 PM Thread Starter
Batan's Avatar
Oil filter question
Change the oil on the Versys the other day and noticed I was given a slightly shorter filter. It's not completely wrong, apparently it was on their list but it's a bit shorter. It appears to be a shorter version of the same filter. In my mind it should be fine but I just wanted to confirm. Next time I'll get the right length. It's a HF204(as opposed to 303 for the V). The Hiflo cross reference chart lists it for an earlier ER6-F.
ER-6f A6F,B6F (EX650) 06 HF 204
ER-6f A7F,A8F.B7F,B8F (EX650) 07-08 HF 303
ER-6f C9F,D9F,CAF,DAF,CBF,DBF (EX650) 09-11 HF 303
ER-6n A6F,B6F (ER650) 06 HF 204
ER-6n A7F,B7F,A8F,B8F (ER650) 07-08 HF 303
ER-6n C9F,CAF,CBF,DBF (ER650) 09-11 HF 303
EX650 A6F,A7F,A8F,C9F,CAF Ninja 650R 06-10 HF 303
EX650 CBF Ninja 650R 11 HF 303
KL650 A1-A19,A6F,A7F,E8F,E9F,EAF,EBF (KLR650) 87-11 HF 123 HFF 2024
KL650 B1,B2,B3 Tengai (KLR650) 89-92 HF 123 HFF 2024
KL650 C1-C9 (KLR650) 95-03 HF 123 HFF 2024
KLE650 A8F,A9F,CAF,CBF,DBF Versys 08-11 HF 303
KLE650 Versys City 11 HF 303
KLE650 Versys Tourer 11 HF 30
Batan is offline
post #2 of 11 (permalink) Old 10-23-2011, 05:12 PM
Heres My Choice.
post #3 of 11 (permalink) Old 10-23-2011, 06:45 PM
How long is it exactly? Are you comparing to an original OEM Kawasaki filter?
post #4 of 11 (permalink) Old 10-23-2011, 08:14 PM Thread Starter
Batan's Avatar
Not sure about the old filter but chances are it's Kawi because the friend the bike belonged to had it serviced at a dealer.
Maybe about 1/2" shorter or so.
Batan is offline
post #5 of 11 (permalink) Old 10-23-2011, 08:36 PM
The filter is fine. There are two version that fit the motorcycle. At least when the 650R came out it had the short filter then I think they switched the spec to the longer filter. Either will work but I think generally most people go with the longer filter. I suppose you have more filter media with the longer filter if that's enough to make you want to use longer filter.
swimmer is offline
post #6 of 11 (permalink) Old 10-23-2011, 08:38 PM
1/2" shorter than what length? How long is it exactly?
post #7 of 11 (permalink) Old 10-23-2011, 08:44 PM Thread Starter
Batan's Avatar
Then the one that was on it(which is very likely an OEM one), I can measure them later.
EDIT: found this, some R1 guys will replace their 204 filters with 303(that is listed for Versys) because they are longer, thus more filtration area.
http://www.yamahafz1oa.com/forum/sho...t=61581&page=2
Batan is offline
post #8 of 11 (permalink) Old 10-31-2011, 12:36 AM
Oil filter same as Weljo. Opened it up at 7000 km with Amsoil 10W-40, clean it and glad to use it again and again.
post #9 of 11 (permalink) Old 10-31-2011, 01:14 AM
2daMax's Avatar
Steven, how dirty is it after 7000km? What do u see?
Previous Ride:
My V's Farkle Log:
2daMax is offline
post #10 of 11 (permalink) Old 10-31-2011, 01:33 AM
Hi Leslie,
Oil was black but free of any solids and any metal. A simply rinse out with the garden hose. Dry well and screw back on. I leave the bike to drain her oil for quite a while.
I can't longer put computer magnets on like the OEM filter but this SS PC Racing Flo filters has a magnet inside.
post #11 of 11 (permalink) Old 10-31-2011, 01:57 AM
For the 2011 V, will stick with the OEM paper filter with mineral oil till 5K. Then will go Amsoil with the SS oil filter.
