Irregular Chain Tension Question - Kawasaki Versys Forum
post #1 of 14 (permalink) Old 10-17-2011, 08:20 PM Thread Starter
Sorry if this one has been asked 3000 times and has been answered already but I scanned hi and low and could not find the answer that I seek.
I just got a new heavy duty DID chain and installed it with new front and rear sprockets. I use a rear bike stand on swing arm spool so the back tire is under no load. I adjusted the chain until I get to what I believe is proper tension and then tighten the axle nut. Doing so seems to to tighten the chain every so slightly more. I then spin the wheel and notice that with my brand new chain there are tight sections and then there are also loose sections. I never had this happen with the EK brand chains in the past and thought that when there was pronounced uneven tension it was a sign of a chain at the end of life--not brand new like this DID chain.
i read that proper tension should be set when the wheel is rotated to the chains tightest section.
So my question is, is it ok that a brand new DID chain has ~1.5 inches of slack in one section and as much as ~2.5 inches in other sections?
Just super worried there is something way more sinister wrong with my bike and wish to resolve this one before rolling again.
Thanks.
Matt from Cape Canaveral, Florida
Current Bikes
2015 Triumph Street Triple R -- Matte Black
2013 Ducati MultiStrada -- Base Model
2011 Triumph Speed Triple -- Black
mjfields_228 is offline
post #2 of 14 (permalink) Old 10-17-2011, 08:41 PM
Thanks.
We are pretty much in synch LOL... about few second of asking pretty similar question check this out :
http://www.kawasakiversys.com/forums...ad.php?t=17339
..but in my case still running the old one.
burnedstar is offline
post #3 of 14 (permalink) Old 10-17-2011, 09:09 PM
Pismocycleguy's Avatar
Talking Chain Slack
Go to web posting, forum posting, as mentioned in above entry/messsage.
“Don’t bother me with DETAILS!”
Pismocycleguy is offline
post #4 of 14 (permalink) Old 10-17-2011, 09:43 PM
Hardware's Avatar
... is it ok that a brand new DID chain has ~1.5 inches of slack in one section and as much as ~2.5 inches in other sections? ...
I wouldn’t expect to see any significant variance in the slack with a brand new chain and sprockets – and IMO the amount that you’re seeing means that something’s wrong...
Did the rear sprocket center on its mounting bolts well?
~~ Live Like You're Dying ~~
Hardware is offline
post #5 of 14 (permalink) Old 10-18-2011, 12:09 AM
"A new heavy duty DID"? Which DID chain model is it, where did you get it from, and how sure are you that it's new?
I'd be surprised if your countershaft was bent. Did you get an aftermarket front sprocket without the rubber damper?
post #6 of 14 (permalink) Old 10-18-2011, 05:42 AM Thread Starter
I got a Superlite/D.I.D. 520ZVMX Chain (rated for 1200CC) & Steel Sprocket Kit from Sprocketcenter. There was no rubber damper on my original stock front sprocket and the after market does not have one either.
Current Bikes
post #7 of 14 (permalink) Old 10-18-2011, 06:19 AM
Original stock front sprocket without rubber damper on a 2009 you got when it was new?
post #8 of 14 (permalink) Old 10-18-2011, 08:41 AM Thread Starter
When I pulled the original front sprocket off last year (after 17500 miles or so) there was only the sprocket and the lock (star) washer under the 27mm nut. No rubber damper or spacer.
Current Bikes
post #9 of 14 (permalink) Old 10-18-2011, 10:48 AM
Originally Posted by Hardware View Post
Did the rear sprocket center on its mounting bolts well? .
10-4. Rec'm pulling rear wheel and loosening/retightening rear sprocket bolts gradually tightening bolts on opposite sides. I have never had a good new chain/sprockets with any variation in chain sag.
2004 Hon XR250
2004 Kawi KDX220
2006 Suzi DL1000
2009 Suzi DR650
2011 Kawi 650 Versys
oldturtle is offline
post #10 of 14 (permalink) Old 10-18-2011, 03:19 PM
Velocibiker's Avatar
It could be a bad chain or sprocket - OR - The new chain might still be 'sticky' with all the fresh packing & shipping grease. I hate to ask the obvious, but did you clean it and lube it? If so, take it for a short spin to warm it up and see if it's still binding. If so, then something is bad. Just make sure you have the minimum amount of slack at the tightest point to start.
Velocibiker is offline
post #11 of 14 (permalink) Old 10-18-2011, 05:33 PM
It is possible for the new chain links to be a bit stiff still. Check for proper tension again after a few easy miles... Original sprocket has a rubber damper bonded to both sides as a single unit.
post #12 of 14 (permalink) Old 10-18-2011, 06:47 PM Thread Starter
Issue resolved! Everyone's input helped! First, I cleaned the shipping grease off and ran it for a few minutes. That helped a little but it was still hanging up in areas. So then I analyzed exactly where the chain was getting tight in the rotation sequence and it was when the chain passed approx. a one quarter section of the rear sprocket. So that was clear to me that it was deflecting somehow on that one section. So I removed the rear wheel and pulled the sprocket hub out of the rear wheel hub (the rubber bushing thingy) and notice that perhaps I was too liberal with the hi-temp grease in there around the axle bearing area and some build up and dirt may have migrated from the axle bearing area to the flat surface area causing the deflection. So I clean it thoroughly. I then removed the sprocket from the hub and turned it 180 degrees from its original bolted position, and as one posted recommended, carefully re-torque using the cross pattern method. I always cross torque but may have rushed it last night and when to full torque on all 6 bolts right away. This time however, I took it to a low torque, a medium torque and then a final torque using the cross pattern.
Bottle line is that all three factors (sticky chain, inner/outer hub alignment and torque method) contributed to my issue. I am much relieved that something more sinister is not at play here.
Thanks to all for giving me plenty of ideas to work with.
Matt from Cape C out..........
Current Bikes
post #13 of 14 (permalink) Old 10-18-2011, 08:11 PM
Baron650's Avatar
I love a happy ending, to the forum!
Baron650 is offline
post #14 of 14 (permalink) Old 10-18-2011, 08:42 PM
2daMax's Avatar
I wouldn't have thought about the rear sprocket damper not seated properly to be a possible thing. Good info and glad the problem is solved.
Previous Ride:
My V's Farkle Log:
2daMax is offline
