Hard starting when warmed up - Kawasaki Versys Forum
post #1 of 8 (permalink) Old 10-14-2011, 06:08 AM Thread Starter
glowcat13's Avatar
I am just looking for possible causes, my versys starts first time everytime when I start it cold, but after its warmed up from riding awhile and i stop for gas or take a break and then go to restart it usually takes 3 or 4 attempts before she fires up. Does this happen to anybody else, anyone know why this might happen.
Plus this will be my 1000 post, finnally.
Those who say money can't buy happines haven't bought A VERSYS.
glowcat13 is offline
post #2 of 8 (permalink) Old 10-14-2011, 06:18 AM
offcamber's Avatar
I'm really just guessing but I wonder if a vent is partially clogged...my theory....when you been riding its drawing fuel causing a vacuum situation in the tank....when it sits it has time to equalize the pressure....
I could be way off....
offcamber is offline
post #3 of 8 (permalink) Old 10-14-2011, 07:08 AM
CanadianFZ6's Avatar
How many miles on the bike? Have you had a valve adjustment done? Hard starting when warm can be a symptom of overly tight valves...
'14 Versys 650 (Green)
'14Honda CB500x
CanadianFZ6 is offline
post #4 of 8 (permalink) Old 10-14-2011, 07:09 AM
What is your hot idle speed? Have you checked TPS voltage?
David RSparky3 is offline
post #5 of 8 (permalink) Old 10-14-2011, 07:56 AM
I had something very similar to this .
It would start first time, but then would not restart - this happened over a period of about 6 months until it got to the point that I could not start her at all.
Turned out it was a faulty relay but the mechanic had to go through testing everything to find it. Wasnīt a cheap repair but touch wood itīs been ok since.
spainy is offline
post #6 of 8 (permalink) Old 10-14-2011, 08:52 AM Thread Starter
glowcat13's Avatar
I was wondering if this might be the cause as I am past due for the valves to be checked and adjusted.
post #7 of 8 (permalink) Old 10-14-2011, 11:10 AM Thread Starter
glowcat13's Avatar
looks to be around 900 rpm
post #8 of 8 (permalink) Old 10-14-2011, 12:22 PM
Turn it up to 1300 + or ~ 50
