DIY synch tool - Kawasaki Versys Forum
post #1 of 11 (permalink) Old 09-30-2008, 12:38 PM Thread Starter
Guest
DIY synch tool
Can I make my own with a couple of vacuum guages? Has anyone here done this? Thanks
Magnaversys is offline
post #2 of 11 (permalink) Old 09-30-2008, 12:49 PM
If you have a couple of gauges, what are you trying to make? The "sync tool" that some people make is used in place of actual vacuum gauges. If you've got two gauges, hook one each up to your vacuum ports on the two cylinders and see what you've got. The only thing to watch for is whether the two gauges are calibrated correctly. I might use each gauge on one cylinder to see if they read the same, then hook both up and tune away.
blz2dwl is offline
post #3 of 11 (permalink) Old 09-30-2008, 01:26 PM Thread Starter
Guest
Didn't realize it would be that simple. Any idea of what the range of the guages should be? Thanks
post #4 of 11 (permalink) Old 09-30-2008, 02:50 PM
Guest
kawifan is offline
post #5 of 11 (permalink) Old 09-30-2008, 03:23 PM
DragonBreath's Avatar
That is really good information in that link kawifan. Thanks for that.
Chris in Oneonta, NY
>>>> states on a bike <<<<
>>>> East Coast done <<<<
>>>>> Westward HO! <<<<<
DragonBreath is offline
post #6 of 11 (permalink) Old 09-30-2008, 03:24 PM Thread Starter
Guest
Originally Posted by kawifan View Post
Genius! I love simple solutions!
post #7 of 11 (permalink) Old 09-30-2008, 03:51 PM
Darth Lefty's Avatar
The bottle method works better, easier to show level and with no worries you're going to suck anything you don't want into the intake. However it does require that you buy and consume at least two beers.
I'm calm like a bomb!
Darth Lefty is offline
post #8 of 11 (permalink) Old 09-30-2008, 06:36 PM
The old manometer I used is of the same design but about 2 feet tall and uses coolant instead of water as it's a bit heavier and colored. There is also a restrictor in the hose on both sides near the top to reduce the pulsing for a more stable reading. They're metal plugs with a tiny hole in the middle... If you build the DIY gauge, you might want to try sticking an equal lenght of a pen's plastic ink cartridge that has the insert in the end. It fits pretty snuggly in 5/32" (3.83 mm) ID hose, in both sides near the top. It would also reduce the risk of ingesting enough water to cause hydro-lock and bend a connecting rod, which could pretty much ruin the day...
post #9 of 11 (permalink) Old 09-30-2008, 10:31 PM
Guest
Years ago I tried to use vacuum gauges to do a carb sync - don't bother, the needles bounce all over the place as the pressure in the intake changes and the gauges are not cheap - just buy the right tool with the liquid in the tubes instead and save yourself the headache.
heehaw is offline
post #10 of 11 (permalink) Old 10-01-2008, 09:39 AM Thread Starter
Guest
Actually... what prompted the question in the first place is a local farm supply store has guages for $2.99 each... Just the guage, no nipples, hoses or anything else....
post #11 of 11 (permalink) Old 10-02-2008, 11:33 PM
Guest
I have an old mercury tube carb sync tool. it works very well as long as you don't rev the motor too fast and suck up the mercury out of the tube. I believe I paid about $25 for it and it works with 2-4 carb setups very well.
Zeniac is offline
Similar Threads
How do you synch the TBs? Magnaversys Technical Discussion - V-650 22 01-30-2009 10:53 AM
Tool Kit rdbeard General Discussions - V-650 10 08-26-2008 11:50 AM
Awesome multi-tool leshall Modifications - Cosmetic - V-650 2 08-15-2008 04:57 PM
