Valve check report - Kawasaki Versys Forum
post #1 of 21 (permalink) Old 07-28-2011, 09:09 PM Thread Starter
Mchustlr's Avatar
Valve check report
Just had valves checked and new air filter today at 17,850 miles.
Valves were all on spec...
so...$170 air filter.
Mchustlr is offline
post #2 of 21 (permalink) Old 07-28-2011, 09:45 PM
So valve check was less than 170? My dealer wants to charge like 400 for the valve check.
rumbo75 is offline
post #3 of 21 (permalink) Old 07-28-2011, 09:50 PM
I do it on mine for free. Air filter can also be cleaned and re-oiled instead of replaced.
post #4 of 21 (permalink) Old 07-28-2011, 09:54 PM
How long does it take you invader? Start to finish?
rumbo75 is offline
post #5 of 21 (permalink) Old 07-28-2011, 10:13 PM Thread Starter
Mchustlr's Avatar
We have a good local mechanic and we take our bikes there all the time. My boyfriend also had some stuff done on his bike so he worked out a package deal
Mchustlr is offline
post #6 of 21 (permalink) Old 07-28-2011, 11:56 PM
If you can change the spark plugs you can do a valve check. If you dont break a spark plug like I did the check should take about 60 minutes more than the plug replacement. Add another 60-90 for replacement of shims that are out of tolerance. I have a long thread about my ordeal, but even after my troubles I would say don't pay to have it done, do it yourself.
Steve
lonerockz is offline
post #7 of 21 (permalink) Old 07-29-2011, 05:33 AM
I don't time myself. I just do it as well and meticulously as possible over the long winter months. I take extra time to clean out all the crevaces and stagnant oil out of it, clean the rust off PAIR steel tubes then lightly coated with high heat anti-seize compound. I thinned down some original shims by hand on wet emery cloth, and switched some around to have them all at 0.18mm inlet and 0.26mm exhaust. Reassemble with oil on moving parts, gap and index spark plugs, etc...
post #8 of 21 (permalink) Old 07-29-2011, 05:37 AM
Wow, so you're a girl on a white Versys? Cool.
Did you get a chance to know what your valve clearance measurements were at?
post #9 of 21 (permalink) Old 07-30-2011, 11:16 PM
mminob's Avatar
Index Spark Plug?
Could you please explain Index Spark Plug ..Thank you,
2013 White 650 Versys...Purrs like a kitty cat...
2007 Yamaha WR250F...Dirt Ripper...
mminob is offline
post #10 of 21 (permalink) Old 07-31-2011, 10:57 AM
I'm not sure I have the confidence to do it myself.
LOL!! The thread title..."how have I screwed it up" doesn't make me feel much better about trying it!
rumbo75 is offline
post #11 of 21 (permalink) Old 07-31-2011, 12:46 PM
Indexing
Indexing spark plugs generally refers to using shims under the spark plug so when it is torqued properly the electrode is facing a direction as to give maximum exposure of the spark to the fuel mixture. This is done mostly on race vehicles and I don't bother with it myself.
dct73 is offline
post #12 of 21 (permalink) Old 07-31-2011, 03:15 PM
Indexing isn't really advantageous on 4 valve engines because of the central plug location. It's more important on engines with the plug on one side of the chamber.
09 Versys
00 KLR
USN 1959-65
ttpete is offline
post #13 of 21 (permalink) Old 07-31-2011, 06:42 PM
When I did the valves on my '08 at 21,000 miles, NOT counting going to the dealer to get some shims (NEXT time I'll do what "Invader" does and 'work' them down on emery paper) carrying my metric caliper to check ACTUAL sizes (which were OFF considerably from advertised sizes...!), probably took 3 hours, but I'm pretty anal.
post #14 of 21 (permalink) Old 08-01-2011, 11:07 AM
Hardware's Avatar
Spark Plug Indexing
As Pete said above, Spark Plug Indexing on a 4-valve head won’t make a perceptible difference.
IMO things like this are “Mechanic's Masturbation”. It can feel good to do it, it won’t harm anything... but when it’s done, it won’t produce any real world consequence either
I do admire Invader’s attention to detail though. He sure does strive for perfection...
~~ Live Like You're Dying ~~
Hardware is offline
post #15 of 21 (permalink) Old 08-01-2011, 12:43 PM
The 10mm plugs used in my Ducati have TWO side electrodes......
09 Versys
00 KLR
USN 1959-65
ttpete is offline
post #16 of 21 (permalink) Old 08-01-2011, 08:03 PM
I think 10mm spark plugs with 2 ground electrodes (NGK CR9EK, Denso U27ETR) are not available with an iridium center electrode.
post #17 of 21 (permalink) Old 08-01-2011, 11:07 PM
cuff's Avatar
just doing mine right now and it's a good thing. Two of the exhaust valves were tight by .15, one was tight by .05 and all the others were spot on including all intake valves. Kind of easy if you're not scared and don't need the bike right a way. That takes a lot of pressure off.
Kind of crappy that there is no numbers on the shims and my micromiter is crap. At least I only need 3 of them and all are on the same cam so only one had to come out.
I did notice that the O-ring on the cam chain tightener is going so this saves me an oil leak.
IBA# 38547
cuff is offline
post #18 of 21 (permalink) Old 08-02-2011, 01:21 PM
Actually, it's NGK MAR10A-J. And it's conventional. Doesn't matter because the valve lash needs to be checked and belts changed every 7500 mi, and they get replaced then.
09 Versys
00 KLR
USN 1959-65
ttpete is offline
post #19 of 21 (permalink) Old 08-03-2011, 02:19 PM
angst's Avatar
Time for valve check.
Probably two and a half hours. Maybe less, I have gotten fast at it.
Cheers!
angst is offline
post #20 of 21 (permalink) Old 08-03-2011, 03:54 PM
ttpete;....are we still talking VERSYS.....or has a Ducati reared its ugly head ? ?
....belts, dual electrode plugs....say it aint so
Cheers
rcfield is offline
