HOWTO: Raising the V with a car jack - Kawasaki Versys Forum
post #1 of 4 (permalink) Old 06-17-2011, 10:20 PM Thread Starter
I recently added Speedy's lowering kit which required lifting the rear wheel off the ground without supporting the swing arm. Here's what I did:
1) With the V on its side stand, put a jack stand under the right-side peg. Put it under the hinge part of the peg that doesn't fold up. The shape of that hinge makes it pretty secure on the jack stand. The jack stand should be set so it just barely fits under the peg. If needed, you can make it slightly higher, then pivot the V over so it's supported on the side stand and front wheel, slide the jack stand under the peg, then set the V back down.
2) Align the car jack under the left-side peg. I recommend using a car jack with wheels under it because the bike is going to step out as it raises.
3) Start raising the car jack. Keep a hand on the seat handles to steady things while you pump the jack. Continue pumping until the V is level.
The V will now be resting on the jack, jack stand, and the front wheel. The rear wheel is now free for all your swing-arm maintenance needs.
nebulous13 is offline
post #2 of 4 (permalink) Old 06-17-2011, 11:07 PM
2daMax's Avatar
Good tip and great idea. I did try once with the car jack but used it on the swingarm bobbin and it doesn't look that stable as the jack tends to wanna flip out. Going to try your method but with just the jack on the right peg for chain maintenance.
Previous Ride:
My V's Farkle Log:
2daMax is offline
post #3 of 4 (permalink) Old 06-18-2011, 06:49 AM
blackberry's Avatar
One thing I would ad is to use a ziptie around the front brake handle and grip to keep the bike from rolling.
blackberry is offline
post #4 of 4 (permalink) Old 06-18-2011, 08:32 AM
G19Tony's Avatar
When I did my lowering kit project, I put a jack stand under the right passenger footpeg bracket, then I lifted the bike by the passenger handle and slid the other jackstand under the left pax footpeg. The right stand tilted out some, but came back level.
G19Tony is offline
Tags
jack, lift, raise, stand
