How do you lubricate the throttle cable? - Kawasaki Versys Forum
 1Likes
  • 1 Post By invader
post #1 of 12 (permalink) Old 06-12-2011, 01:41 PM Thread Starter
Does anyone know how to lubricate the throttle cable? Do I need to take it off at the top? I'm not even sure how to do that.
rumbo75 is offline
post #2 of 12 (permalink) Old 06-12-2011, 04:06 PM
I would think that info is available on this site - some threads would cover it.
If all else fails, check the owner manual.
toofer is offline
post #3 of 12 (permalink) Old 06-12-2011, 04:53 PM Thread Starter
Thanks toofer...I would think so also but after a quick search I didn't find anything about lubing the throttle cable. My owner's manual also does not cover it.
rumbo75 is offline
post #4 of 12 (permalink) Old 06-12-2011, 05:15 PM
http://www.motionpro.com/motorcycle/...y/cable_luber/
post #5 of 12 (permalink) Old 06-12-2011, 05:18 PM Thread Starter
Weljo...I have one of those. But I don't know how to take off the cable. Like you mentioned before, maybe I don't need to do it. I don't really know.
rumbo75 is offline
post #6 of 12 (permalink) Old 06-12-2011, 08:17 PM
Yes you have to remove the screws and pop the throttle cover off... From the service manual:
Cables: Lubricate with Rust Inhibitor.
Clutch Cable /Throttle Cables
•Lubricate the cables by seeping the oil between the cable and housing.
○The cable may be lubricated by using a commercially available pressure cable lubricator with an aerosol cable lubricant (or chain lube).
•With the cable disconnected at both ends, the inner cable should move freely within the cable housing.
If cable movement is not free after lubricating, if the cable is frayed, or if the cable housing is kinked, replace the cable.
You can also clean and grease the throttle grip tube on the handlebar.
andyversystheworld likes this.
post #7 of 12 (permalink) Old 06-12-2011, 08:28 PM Thread Starter
Invader is it just the 2 screws on the back side? I couldn't get the housing off.
Do I have to take the bar end weight off?
rumbo75 is offline
post #8 of 12 (permalink) Old 06-12-2011, 09:52 PM
It's just the 2 screws... Other mechanically challenged members have also had a hard time opening it, then managing to position the cable ends back in and routed. You can do the cables and have reasonable access to grease the throttle tube without removing bar end.
post #9 of 12 (permalink) Old 06-12-2011, 09:55 PM Thread Starter
LOL!
Ok, thanks. Yea, for some reason I couldn't get it to pull apart. I wasn't sure if I needed to take off the bar end weight to grease the throttle tube.
One last question. There's 2 cables right? Do both of them get lubed? I would assume yes....
Maybe I'll have better luck tomorrow.
rumbo75 is offline
post #10 of 12 (permalink) Old 06-12-2011, 10:00 PM
Yeah both throttle cables (pull and return) get lubed, as does the clutch cable.
post #11 of 12 (permalink) Old 06-12-2011, 10:05 PM
There's a protruding dowel on the bottom half of the cover in a hole in the handlebar, keeping it from twisting and moving around. Bottom half gets pulled down to clear the dowel out of handlebar.
post #12 of 12 (permalink) Old 06-12-2011, 10:46 PM Thread Starter
Thanks invader
rumbo75 is offline
