Warped front rotor?? - Kawasaki Versys Forum
post #1 of 11 (permalink) Old 06-07-2011, 11:26 PM Thread Starter
Mark Jags's Avatar
One or both of mine definately are. Not even 2500 miles on the bike and when I use the front brake to slow down to a stop, like at a traffic light, it grabs-releases-grabs-releases with steady hand pressure on the brake lever.
Anyone else experience this before?
Mark Jags
[[/FONT]
09 Blue V
03 H-D Sportster - 50K miles and counting...
08 Bonneville - wife's bike
Mark Jags is offline
post #2 of 11 (permalink) Old 06-07-2011, 11:33 PM
It's fairly common on the Versys, although mine is still fine at 6000 miles. Cleaning and lubing the bobbins may help for a while...
http://www.kawasakiversys.com/forums...ead.php?t=2686
http://www.kawasakiversys.com/forums...ead.php?t=5091
http://cgi.ebay.com/ebaymotors/Front...Q5fAccessories
http://cgi.ebay.com/ebaymotors/KAWAS...Q5fAccessories
Is yours still on warranty?
post #3 of 11 (permalink) Old 06-08-2011, 06:59 AM
stagehand38's Avatar
11,200 miles on mine....no warp-age and pads still have plenty of meat on them.
Do you use engine braking when coming to a stop?
Just asking......
stagehand38 is offline
post #4 of 11 (permalink) Old 06-08-2011, 08:31 AM
El Tig's Avatar
As invader says clean and lube your bobbins. Mine was acting just as you describe and I just knew I had warped my rotors from some hot stops but some wd-40 and an old tooth brush to clean them and some lube and they were cured. Invader is owed a lot of beer from many of us appreciative forum members!
Ooops, saw my old post about this and must say Red Herring gets credit as well for helping me solve my rotor dilema. No prob since and nearly 44k.
Last edited by El Tig; 06-08-2011 at 08:36 AM. Reason: Red Herring's helpful input
El Tig is offline
post #5 of 11 (permalink) Old 06-08-2011, 08:50 AM
BAMF's Avatar
i was cleaning my chain and could hear my rear rotor touching the pads slightly with each rotation...not really enough to slow it down, i could still spin the wheel easily by hand but i will give this fix a look over.
1997 KLR 650
2011 Halle-friggin-leuya Versys
BAMF is offline
post #6 of 11 (permalink) Old 06-08-2011, 09:02 AM
Rear brake rotor is solid mounted. Only the front semi-floating rotors are mounted on bobbins.
post #7 of 11 (permalink) Old 06-08-2011, 10:48 PM Thread Starter
Mark Jags's Avatar
Thanks guys. I'll try cleaning and lubing the boobins when I get a chance.
The warranty just expired seven days ago.
And I use the engine to brake most of the time, so I don't think I'm overheating the rotors.
Mark Jags
[[/FONT]
09 Blue V
post #8 of 11 (permalink) Old 06-09-2011, 06:02 AM
Rotors are pretty easy to damage, by running into something, for example, or otherwise banging them against something. They're easily damaged during tire changes too, although you probably haven't changed your tires yet.
Mt. Versuvius is offline
post #9 of 11 (permalink) Old 06-09-2011, 06:45 AM
I had the issue described by the OP and solved it (after trying bobbin clean/lube without success) by installing new EBC brake pads.
[SIZE="1"]Ride. Good.
2019 F750GS
2014 R1200RT
2008 Versys (SOLD 11/19)
2003 ST1300ABS (SOLD 5/15)
post #10 of 11 (permalink) Old 06-09-2011, 08:35 AM
Hardware's Avatar
Id check the rotor and wheel runout before I started fixing what may not be broke...
~~ Live Like You're Dying ~~
Hardware is offline
post #11 of 11 (permalink) Old 06-09-2011, 10:35 AM
Stumpifier's Avatar
Most people don't have access to that kinda of equipment and it's easy enough to hit the bobbins with penetrating lube and see what happens. Just make sure you hit your rotor with brake clean if you get any on it. Should that solve the problem personally I'd then take them apart and hit them with caliper grease but I'm anal about that kinda thing.
1982 Honda CB450SC Nighthawk
2009 Green Versys
Stumpifier is offline
