I'm an idiot, need electrical help - Kawasaki Versys Forum
post #1 of 8 (permalink) Old 05-29-2011, 10:08 AM Thread Starter
So my dumb arse left the ignition key in the on position and drained the battery. I discovered this while in a rush (following what was continuing to be a horrible day) and decided an easy fix would just be to give the bike a jump.
Well the problem is In my haste I crossed the jumper cables on the bike and now I cannot get the bike to turn on. I had the battery tested and recharged (was told it was fine) and I checked the fuzes in the small fuze box next to the battery. Everything seems fine but the bike still will not turn on.
Does this mean I burnt out the ECU or some other major electrical component? Any help or advice would be huge.
Layne Beasley
LJBeasley is offline
post #2 of 8 (permalink) Old 05-29-2011, 11:14 AM
Baron650's Avatar
Check the main fuse that is hidden behind the plastic panel out on the left close to battery.
Baron650 is offline
post #3 of 8 (permalink) Old 05-29-2011, 09:07 PM Thread Starter
i'll try that,I knew there had to be more fuses that what is located in that small pannel next to the battery.
to be honest I havnt had much time to mess with the bike since i've been working on the trucks AC. That being fixed I have my whole holiday to get the bike up and running
Layne Beasley
post #4 of 8 (permalink) Old 05-30-2011, 07:42 AM
Lours_Polaire's Avatar
Gee ... That's quite a comitement to admit ALL those back to back mistake ...
Sorry, coudn't resist
With my karma, it's going to happen to me in a little while ...
Hope you get your steed back on is feet !
Ciao
LOP
Lours_Polaire is offline
post #5 of 8 (permalink) Old 05-30-2011, 09:53 AM
Check the:
1. 30A main fuse
2. 15A ECU fuse
3. 10A ignition fuse
4. ECU main relay
Check the service manual where they are. Hope the fuses protected the circuitry.
post #6 of 8 (permalink) Old 05-30-2011, 02:43 PM
post #7 of 8 (permalink) Old 05-30-2011, 05:09 PM
Mursili's Avatar
Please realize that, on this forum, if you own a Versys you cannot be an idiot.
It is also a good idea to listen to Invader's ideas.
Good Luck.
Paul
Mursili is offline
post #8 of 8 (permalink) Old 05-30-2011, 08:33 PM
Good Luck.
Paul
Paul has said two of the main truths of this forum
