Clunking noise only in first gear. - Kawasaki Versys Forum
post #1 of 12 (permalink) Old 05-27-2011, 03:52 AM Thread Starter
narthab's Avatar
I have recently started to notice a clunking noise and feel in only first gear with the clutch fully out. Not sure what this is. Its faint hard to hear and feel but its there. Anyone else having this issue?
narthab is offline
post #2 of 12 (permalink) Old 05-27-2011, 04:46 AM
Excessive chain slack?
post #3 of 12 (permalink) Old 05-27-2011, 06:39 AM
You've got to describe it better than that for anyone to be able to help you.
Mt. Versuvius is offline
post #4 of 12 (permalink) Old 05-27-2011, 12:40 PM
Stumpifier's Avatar
Yeah I could point to a hundred different things right now. Clutch lever fully released, as you roll on the throttle? Does is happen as you put it into first (I'm not clear on what you mean)? More info please
1982 Honda CB450SC Nighthawk
2009 Green Versys
Stumpifier is offline
post #5 of 12 (permalink) Old 05-29-2011, 10:04 PM Thread Starter
narthab's Avatar
chains tight, clutch fully out and with me on the gas.
narthab is offline
post #6 of 12 (permalink) Old 05-29-2011, 10:29 PM
Clunking noise?
post #7 of 12 (permalink) Old 05-29-2011, 11:07 PM Thread Starter
narthab's Avatar
Hard to explain....almost like its going into gear when it already is but not as load as the drop form 2nd to 1st...
narthab is offline
post #8 of 12 (permalink) Old 05-30-2011, 02:11 AM
What year is it? How many miles on chain and sprockets? Is it the engine that's bucking in the lean ~2800 rpm range?
post #9 of 12 (permalink) Old 05-30-2011, 03:17 AM Thread Starter
narthab's Avatar
2008, 14,000 on the bike no new chain or sprocket, only happens in first gear...not sure about the rpm range
narthab is offline
post #10 of 12 (permalink) Old 05-30-2011, 10:48 AM
Your chain might just be stretching out. When I replaced my chain and sprockets virtually all 1st gear clunking noises went away. Bike was also much smoother.
rumbo75 is offline
post #11 of 12 (permalink) Old 05-30-2011, 10:50 AM
Also check your front sprocket. You may have broken teeth or very worn.
rumbo75 is offline
post #12 of 12 (permalink) Old 05-31-2011, 03:12 AM Thread Starter
narthab's Avatar
Looks like I do need a new chain at least...prob gonna do both sprockets while im at it. Chain loosen up after only couple of hundred miles......Thx everybody
narthab is offline
