Fork Tube outer diameter? - Kawasaki Versys Forum
post #1 of 10 (permalink) Old 04-21-2011, 12:09 PM Thread Starter
versysbill's Avatar
Send a message via AIM to versysbill Send a message via Yahoo to versysbill
I would like to get the definitive answer on what the outer diameter of the fork tube is for our Versys bikes? Looking at acquiring some fork tube clamps from Pro-Tek so that i can mount a high Acerbis black motocross fender
I keep seeing 41mm mentioned at various sites but then i also heard that 51mm is the a outer diameter and the 41 is some other measurement on the forks
Talking about the black upper portion of the fork tube beneath the crass clamp
2009 Kawasaki Versys 650 Green
2007 Toyota FJ Cruiser Limited Edition
2002 Honda S2000
versysbill is offline
post #2 of 10 (permalink) Old 04-21-2011, 01:50 PM
CanadianFZ6's Avatar
I am curious as well as I want to get some fork clamps for some aux LEDs...
'14 Versys 650 (Green)
'14Honda CB500x
CanadianFZ6 is offline
post #3 of 10 (permalink) Old 04-21-2011, 04:28 PM
if you specify how high above the dust seal I can take a measurement for you.
Phoneman064 is offline
post #4 of 10 (permalink) Old 04-21-2011, 05:02 PM Thread Starter
versysbill's Avatar
Up just below the clamp connecting both forks just before it tapers
2002 Honda S2000
post #5 of 10 (permalink) Old 04-21-2011, 06:58 PM
cmoreride's Avatar
51.75mm-52.0mm say 52mm
cmoreride is offline
post #6 of 10 (permalink) Old 04-21-2011, 09:13 PM
These should answer all your questions:
http://www.kawasakiversys.com/forums...5&postcount=67
http://www.kawasakiversys.com/forums...+fender&page=4
ednukey is offline
post #7 of 10 (permalink) Old 02-20-2015, 05:11 PM
CONIRM 52mm TOP and BOTTOM?
Can someone confirm that they are 52mm both at the top and at the lower triples?
Some models run different diamter top to bottom on the trees.
jfman is offline
post #8 of 10 (permalink) Old 02-21-2015, 01:31 AM
Wouldn't you want to mount those lower on the fork leg than the OP's fender? The outer diameter of the uppers is different in different parts. I think I measured 48mm where I mounted mine--not certain. More here:
http://www.kawasakiversys.com/forums...578#post741578
davidg is offline
post #9 of 10 (permalink) Old 02-21-2015, 01:01 PM
kawdog's Avatar
If you are asking someone with calipers what the diameter is, you don't need those necessarily.
Perimeter = P, Diameter = D, Radius = r, (D = 2 x r), Pi = 3.1416
P = 2 x Pi x r
P = Pi x D
P / Pi = Diameter
1. Measure the Perimeter with a tape measure (in any or both units, metric or standard: 1 inch = 2.54 cm = 25.4 mm).
2. Divide the Perimeter by 3.1416 (Pi) = Diameter.
3. You're done.
Clamps come in a range of sizes, so this will be accurate enough with round-off error (you don't need to round Pi off to 1,000 decimal points, ha ha.)
kawdog is offline
post #10 of 10 (permalink) Old 02-21-2015, 07:05 PM
I had the joy of realizing there aee lots of different sizes when mounting my aux lights....
08' Versys
HAWKSHOT99 is offline
