Won't start in gear? - Kawasaki Versys Forum
post #1 of 8 (permalink) Old 04-11-2011, 09:30 PM Thread Starter
I had my tires changed on saturday and now my starter won't engage in gear, it has to be in neutral. What would cause this? The mechanic adjusted the clutch cable and tightened up the braking i noticed too.
Christobevii3 is offline
post #2 of 8 (permalink) Old 04-11-2011, 09:42 PM Thread Starter
Dirty switch under clutch lever, might have got it.
post #3 of 8 (permalink) Old 04-11-2011, 09:43 PM
Pretbek's Avatar
You have to pull in the clutch to start it in gear.
If you do pull in the clutch and it still won't start in gear, you have to check the starter interrupt switch... I don't know what it is really called (help me out here guys).
Edit: Too late, I guess you got it already
Pretbek is offline
post #4 of 8 (permalink) Old 04-12-2011, 12:29 AM
RockyMoto's Avatar
Wow.
Ride to live, live to ride.
2009 Kawasaki Versys
2010 Yamaha YZ 250F
2008 Honda CRF 450
2006 Honda CR 250R
I've owned a Maico.
RockyMoto is offline
post #5 of 8 (permalink) Old 04-12-2011, 03:34 AM
The kickstand has to be up to start or run the motor in gear as I'm sure you're aware. Are you sure your kickstand is all the way up though? If it is I would check the kickstand switch is working OK.
post #6 of 8 (permalink) Old 04-12-2011, 05:59 AM
offcamber's Avatar
This is what I was going to suggest.....most likely culprit.
offcamber is offline
post #7 of 8 (permalink) Old 04-12-2011, 07:58 AM
Lours_Polaire's Avatar
What they said !
LOP
Lours_Polaire is offline
post #8 of 8 (permalink) Old 04-13-2011, 11:08 AM
Had that issue on the Green Hornet. Turned out that the plug that goes into the harness just below the clutch lever was not properly connected because a small piece had broken off the plug (possibly when the bike was put together at the dealer. They've ordered a new plug from Kawi....).
