Clutch cable lubing how to and recommendations?? - Kawasaki Versys Forum
post #1 of 3 (permalink) Old 04-09-2011, 03:45 PM Thread Starter
thecreeper77's Avatar
Hoping someone can assist with some knowledge?
08 Versys (Red)
Two Brothers Slip-On V.A.L.E.™ Exhaust
Two Brothers Juice Box
Arrow Headers
Motowerk Lowering kit w/Flatfoot
SW-MOTECH Crashbars/Engine Guards w/Hwy Pegs
SW-MOTECH mirror wideners
Rear Spool Sliders
~Comming soon~
Front Axel Sliders
Red LED Body Kit
1980 Kawi KZ1000 LTD
thecreeper77 is offline
post #2 of 3 (permalink) Old 04-09-2011, 04:02 PM
Pismocycleguy's Avatar
Talking
Do a search for "I broke my clutch cable" and you will find a complete site dedicated to how to lube your clutch cable.
“Don’t bother me with DETAILS!”
Pismocycleguy is offline
post #3 of 3 (permalink) Old 04-09-2011, 09:04 PM
The easiest way I did it a week ago was to fully loosen the cable adjuster on the right side of the engine. Mark the position first, loosen the small lock nut from the long nut and screw them both down toward the clutch actuator. This will give you the needed free play when you detach the clutch cable from the lever. If you do not give the cable enough play first it will be a pain to separate the cable from the clutch lever. There's more step (follow the recommendation above) but doing this first is the easy way with damaging the cable or the lever. I spent over an hour last year trying to get that cable free without bending hardware.
And since your in the lubing mood I would do the throttle cable as well and make sure that it's adjusted according to the operators manual. I had too much slack on the return cable.
cdmoore74 is offline
