Fuseblock relay hookup - Kawasaki Versys Forum
post #1 of 12 (permalink) Old 04-04-2011, 06:45 AM Thread Starter
Is there a convenient place to hook-up the switching relay ? Someplace I don't have to cut into ? The old KLR had an unused 'city light' shielded female bullet connector beneath the front fairing which served the purpose. Any such unused 12v plug on the V ?
Just thought I'd ask before I go cutting into my license plate light wiring.
Jdcooper is offline
post #2 of 12 (permalink) Old 04-04-2011, 09:22 AM
DrTizz's Avatar
Send a message via Yahoo to DrTizz Send a message via Skype™ to DrTizz
Use a wire tap-in squeeze connector, then all you are doing is "tapping" into the line rather than cutting. Much safer and easier to do in a confined space.
http://www.radioshack.com/product/in...rName=Category
2010 Versys ("Black Bengal")
2013 Triumph Trophy SE
"If it can't be expressed in figures, it is not science, it is an opinion...that means you, CNN!"
DrTizz is offline
post #3 of 12 (permalink) Old 04-04-2011, 11:49 AM
Baron650's Avatar
Ditto on the T-tap, I think I did it on the tag light, no problem.
Baron650 is offline
post #4 of 12 (permalink) Old 04-04-2011, 12:02 PM
versysdave's Avatar
I think that I tapped into the tail light. I really like the posi-tap connectors:
http://www.amazon.com/Posi-tap-Connectors-12-18-Gauge-Wire/dp/B00389RUEO
versysdave is offline
post #5 of 12 (permalink) Old 04-04-2011, 01:04 PM
I used the low-beam headlight; so that there is no current draw until the motor is running.
ScottyNeal is offline
post #6 of 12 (permalink) Old 04-04-2011, 04:48 PM
You could open up the bikes stock fuse box and hook it into there. I had my GPS hooked up to my tail light, but had it done in the fuse box, wrapped around the fuse end rather than cut a wire.
08' Versys
HAWKSHOT99 is offline
post #7 of 12 (permalink) Old 04-04-2011, 05:32 PM Thread Starter
Hawkshot
We have a winner ! That sounds like the best, least "invasive" technique. Exactly where on the bikes fusebox did you hook it?
Thank you for that suggestion.
Jdcooper is offline
post #8 of 12 (permalink) Old 04-04-2011, 08:18 PM
bversysb's Avatar
I like the low beam too it keeps more power for starter.
bversysb is offline
post #9 of 12 (permalink) Old 04-04-2011, 09:11 PM
chid's Avatar
I bought 2 connectors male and female, I disconnected the connector from the brake light and put the new connectors between the brake light and the old connector. I added a brake modulator to the wires.
Now if I want to remove the brake modulator and reconnect everything like the OEM, it takes 2 minutes.
Versys 2015 Green
chid is online now
post #10 of 12 (permalink) Old 04-04-2011, 09:23 PM
Originally Posted by Jdcooper View Post
Hawkshot
Open up the small fuse box next to the battery. Take note of which fuse controls what, and pull the proper fuse. I originally had my GPS hooked to the tail light fuse, but after reading the people saying headlight I just switched fuses.
With a low gauge wire strip the end about a 1/2". Do'nt twist it as that will take up to much room.
Bend the stripped end in half and semi stick it into one side of the fuse holder. It wont want to go in to well, but when you stick the fuse in with it, it goes down good.
i cut a small notch in the side of the fuse box to run the wire out of so the lid will close properly.
I had my GPS set up like this so it would auto shutoff. I just installed a FZ-1 Fuzeblock as I have more gadgets now, and used this technique for the relay wire. After a few people saying to hook it to the headlight to get more cranking power I hooked it to that fuse this time. However the relay still kicked on when the key was turned so it did not work out, but i never had a problem with stuff coming on before start up before.
08' Versys
post #11 of 12 (permalink) Old 04-06-2011, 08:48 PM Thread Starter
Done! Works like a champ.
Jdcooper is offline
post #12 of 12 (permalink) Old 04-07-2011, 07:13 PM
I would recommend NOT doing this. You have a power interruption when you hit high beam (I tried that for my GPS, at FIRST). Instead I used the DRLs (daytime running lights) as they don't change.
