White Residue in gas cap keyhole - Kawasaki Versys Forum
post #1 of 11 (permalink) Old 09-03-2008, 08:58 AM Thread Starter
Guest
Hi,
Is anyone else experiencing a white residue inside the gas cap keyhole? If so, any solutions?
2008 Versys
Dell33 is offline
post #2 of 11 (permalink) Old 09-03-2008, 05:24 PM
furley's Avatar
Yes, it's a good idea to lube it once and a while with some WD40. Just a little bit into the lock cylinder. I have heard of them seizing.
________
Suzuki Alto Lapin History
furley is offline
post #3 of 11 (permalink) Old 09-03-2008, 06:20 PM
Lukejt's Avatar
Do yourself a favor and use something better/longer lasting than WD. WD is a short term solution, and might wash out any grease in there making it worse in the long run.
Lukejt is offline
post #4 of 11 (permalink) Old 09-03-2008, 08:22 PM
furley's Avatar
What would you suggest? That is, if I'm going to do myself a favour!
________
Weed vaporizer
furley is offline
post #5 of 11 (permalink) Old 09-03-2008, 09:19 PM
Lukejt's Avatar
LOL, I'm not a locksmith, always thought they called for graphite or something, but I was thinking of spray lithium grease maybe, or perhaps that Dupont Multi Use dry teflon wax everybody is raving about in the chain lube thread. I just picked up a can at the Home Depot and it says it's good for locks.
I've got padlocks on top of my van keeping my ladders hooked up. I've tried to use WD on the locks when they begin freezing up because I've always got a can or two handy, but it only works for a very short amount of time. I've had better luck with plain old oil for lubrication and corrosion protection.
Lukejt is offline
post #6 of 11 (permalink) Old 09-03-2008, 09:49 PM
Guest
gun oil works great
heehaw is offline
post #7 of 11 (permalink) Old 09-04-2008, 12:28 AM
nvoelsch's Avatar
Used WD40 three weeks ago when my starting seizing. Been through rain storms and sand storms, and no problems so far. And yes, a little WD40 does go a long way...
nvoelsch is offline
post #8 of 11 (permalink) Old 09-04-2008, 07:28 AM
furley's Avatar
i thought of wd40 because it is petroleum based, worried about any other products running down and mixing with the gas, it's such a small amount i guess it doesn't matter as long as you occasionally lube it with something!
________
Vapir no2 price
furley is offline
post #9 of 11 (permalink) Old 09-04-2008, 09:50 AM
Guest
I make a habit to squirt a lil WD40 in all locks, cables, switch-housings, etc after every wash...
Magnaversys is offline
post #10 of 11 (permalink) Old 09-04-2008, 12:56 PM
I use fishing reel grease. Water resistant, has graphite, lasts a long time. Added this to my oil change checklist.
Dan
$100 for gas...
I'm going riding!
ddouble is offline
post #11 of 11 (permalink) Old 09-27-2008, 03:09 AM
Dupont Teflon Dry Wax Lubricant
The dry teflon stuff is safest.
WD40 is too short-term.
Other oils will eventually harden and will often attract and trap grit making things worse.
Low Temp Gun Oil will work well but doesn't last long once it gets wet. Graphite oils work well for short-term, but graphite eventually absorbs water and goes from a lubricant to an abrasive!
I have worked with some amazing Tribologists and Molydisufide or dry teflon are their 2 recommendations for reliable open-air lube. With the water exposure the best results is with the Teflon Dry Wax lube. Not just for locks, but kickstand and chain too!
2xadv is offline
Similar Threads
White Versys David F. Modifications - Cosmetic - V-650 21 04-25-2010 09:57 PM
greetings from the great white north scooter650 Member Introductions 1 07-12-2008 05:54 AM
From the great white north bungie4 Member Introductions 6 02-22-2008 07:54 PM
