Wiring an ignition switch - Kawasaki Versys Forum
post #1 of 3 (permalink) Old 09-01-2017, 08:13 AM Thread Starter
2012 650 Versys, In my previous post you'll see the bike was in an accident and I got it for cheap and swapped the front end from a CBR929. My problem is fitting the verses ignition into place. Its too long and bulky to fit correctly. So i will be fitting an older 4 pin ignition from another bike to it.
My bikes ignition is currently a 7 wire ignition switch and I need to wire it into a 4 wire switch.
My current 7 wires are - White (Power to ignition), Brown (hot from ignition to fuse in ON), Grey (signal with inline resistor for security to computer), Red (hot to lights in ON), Blue (hot to lights in ON), Wht/GRN (lights acc), Wht/Blk (power to ignition).
When the Ignition is ON the following are connected - Red and Blue, W/Grn and W/Blk, White and Brown, and Grey to ignition.
On my 4 pin ignition I believe the wiring is as follows:
Black IG All black wires- all feeding 12V
Brown/W TL1 (headlight switch)
Red BAT (main fuse)
Orange TL2 (tail light fuse)
From the wiring diagram Ive found RED is the main power and would correlate with my WHT wire. Orange only seems to feed the rear tail light. Brown goes to the speedometer lights, and handle bar switches. Black goes to everything that needs power - tail light oil light, turn signal buzzer, headlight, some of the handle bar switches.
As I figure this out I am editing this until someone replies. My main question is why there are separate wires for the tail light (orange wire) on the honda ignition, and on my ignition there are 3 different wires that feed the turn signals (W/G), license plate lights (Red) , and brake light (Blue). Then the brown feeds headlight, stop/start switch, reg/rec, etc. Best I can figure, on the 4 pin Ign, the tail light is separate so in the 3rd key position battery feeds the lights only (parking lights/tail light).
Ok, so heres where Im at.
7 Pin Ign - Brown seems to feed everything (headlight, Reg/Rec, Stop/Start) so that should go to Black of 4 pin, since black seems to feed everything.
7 Pin Ign - Red and White are connected in PARK and 4 PIN Red and Orange are connected. So Red to Orange wire
7 Pin Ign - White obviously goes to Red 4 pin since they both come from battery Positive and feed the other wires in ignition
7 Pin Ign - remainders go to Brown 4 pin.
I did notice on the 7 Pin in park - White red connected. W/Blk and W/Grn are connected. So this throws me for a loop since the 4 pin can only connect orange and red. Would I wire w/blk and w/green together at the Orange as well as at the Brown?
Ive included pics of the ignitions position connections
Name:	Screen Shot 2017-09-01 at 12.03.05 PM.jpg
ID:	131362   Click image for larger version
Name:	Screen Shot 2017-09-01 at 12.02.47 PM.jpg
borjawil is offline
post #2 of 3 (permalink) Old 09-01-2017, 02:42 PM Thread Starter
Well that did the trick. Only difference is the white and black goes to the white.
borjawil is offline
post #3 of 3 (permalink) Old 09-01-2017, 09:17 PM
You have it sorted out??, too late in the evening to try and understand what the ignition and tail light wiring has in common.
onewizard is online now
