New bike wouldn't start - Kawasaki Versys Forum
Like Tree12Likes
  • 3 Post By timster
  • 2 Post By onewizard
  • 1 Post By fasteddiecopeman
  • 1 Post By andyversystheworld
  • 1 Post By onewizard
  • 1 Post By NightRider
post #1 of 18 (permalink) Old 08-30-2017, 07:51 PM Thread Starter
2017 650 LT with 70 miles on it. Drove it to work this morning and got there at 7:45a. No issues. About an hour after I arrived it began to rain. Heavy downpour for about 10 min, then cleared up. Sunny and warm the rest of the day. I went to leave at 3:45. Turned the key while standing next to the bike and the display lit up, headlight came on. Pushed the starter and nothing. Turned the key off, tried again, nothing. Tried a third time. Had power (display, horn, signals, etc.)...just wouldn't start. Then I remembered reading something about faulty kickstand switches and how they could strand you (the bike was in neutral by the way). I sat on the bike, raised the stand and lowered it again. Turned the key on, hit the starter and it fired right up. What might have caused this? Could the rain have messed with a switch?
Bale2011 is offline
post #2 of 18 (permalink) Old 08-30-2017, 08:15 PM
timster's Avatar
That should not be happening on a new bike? I would be headed back to the dealer if you cant find any obvious loose connections. Haven't had any problems on my 2016.
timster is offline
post #3 of 18 (permalink) Old 08-30-2017, 09:15 PM
james75's Avatar
Agree with above, take it back to the dealer. Water should have no affect on it. Motorcycles are made to get wet. Possibly a bad connection or just a faulty switch.
james75 is offline
post #4 of 18 (permalink) Old 08-30-2017, 09:27 PM
Couple things, the kickstand has nothing to do with starting when in neutral, unless you have a poor ground on the neutral switch. .Not going to spend much time here, it is under warranty. First you said you started with the Stand Down, normally it will only start with the stand up and the clutch pulled in while in any gear. When in neutral you can start stand down or stand up, doesn't matter.
silviefox and NightRider like this.
post #5 of 18 (permalink) Old 08-31-2017, 11:08 AM
Rotten Ronnie's Avatar
Send a message via Skype™ to Rotten Ronnie
I had this problem while touring in Nova Scotia.
It turned out the clutch switch connector had become separated. Squeezed it back together to sort it out.
Hope this helps.
2009 Kawasaki Versys 650, 2001 Honda XR400R (street plated)
Ride Reports and other drivel:
Rotten Ronnie is offline
post #6 of 18 (permalink) Old 08-31-2017, 05:42 PM
SOMEHOW (I'll bet) your bike thought it was in gear..., or WAS.
aboyandhisversys likes this.
post #7 of 18 (permalink) Old 08-31-2017, 07:04 PM
So it started with the stand down
Must be they wired the 2017 different, my bike won't start with the stand down no matter if the clutch is in and I am doing the happy dance with my feet.
post #8 of 18 (permalink) Old 09-01-2017, 12:32 PM
NightRider's Avatar
This 2017 V (don't know about previous models), same as mine, has a sensor that shuts down the engine the moment the bike is dropped on the side.
I haven't read the instructions beforehand so I learned the slow way that once you get the bike up, you can't start it until you turn the key to off first (to reset the sensor).
So in case you accidentally drop it, you should know this (hopefully you won't need it).
NightRider is offline
post #9 of 18 (permalink) Old 09-01-2017, 07:35 PM
[QUOTE=NightRider;1436954]This 2017 V (don't know about previous models), same as mine, has a sensor that shuts down the engine the moment the bike is dropped on the side.
So in case you accidentally drop it, you should know this (hopefully you won't need it).[/QUOTE
Tip over sensor 2007 on, all have them, and yes it is a signal to the ECU, motor will crank, but won't start until you key off. Yup, how would I know that, from experience, you know one of those oh s****T and all I have is my front brake and push steering, yes, down you go. Embarrassing when riding with someone and they turn around and your laying on the road having a nap, with the bike on top of you, so you pick it up, everything is good, ignition is still on, hey lets Go. OH OH it won't start, first thing through your mind s***T , then , WTF did I break, then your brain common sense and knowledge kicks in, tip over switch, yup , been there done that. Thought we all could use some entertainment with all the disasters going on
Rotten Ronnie and quexpress like this.
post #10 of 18 (permalink) Old 09-01-2017, 08:09 PM
andyversystheworld's Avatar
Kill switch in "run" position? Kick stand up and down a few times? Bike in neutral? Let us know what it was!
BEST,
ANDY
Visit me at andyversystheworld on Facebook for Pictures and Updates.
andyversystheworld is offline
post #11 of 18 (permalink) Old 09-02-2017, 07:14 AM Thread Starter
Well, I still don't know. The bike has started/stopped and run flawless over an additional 120 miles. The bike had been in neutral, kill switch in run position, etc. What seemed to change things was when I raised and then lowered the kickstand. I can routinely stand next to the bike and start it to let it warm up with the kickstand down.
Bale2011 is offline
post #12 of 18 (permalink) Old 09-02-2017, 08:02 AM
Detail/ Chain of Events
Your kind of post is what I did for a living, trouble shooting inverters/drives/anything electric, and I continue even being retired. Your description / detail/ and chain of events seems very clear to me, no doubt in my mind that what you describe is exactly what transpired. Just looked at the electrical drawing, the kill switch engine / stop switch, supplies power to the stick coils and to the start button/ relay circuit. Keying on , the pump primes, the City lights come on ( you mentioned headlight on, which shouldn't be, if it is please double check that) but pressing the start button nothing happens, as the kill switch supplies power to the start button.
So if you ever have a similar problem, try operating your kill switch without keying off.There have been members that have had the kill switch give them trouble, bike stored outside etc., but on the MK-1 and MK-2, the MK-3 has seen some major changes to covering the electrics and protection from water of these . One thing that is significant is there are 6 frame grounds on the MK-3.
andyversystheworld likes this.
post #13 of 18 (permalink) Old 09-02-2017, 04:05 PM
...I can routinely stand next to the bike and start it to let it warm up with the kickstand down.
Which is how it's designed to operate.
post #14 of 18 (permalink) Old 09-03-2017, 03:30 AM
NightRider's Avatar
There have been members that have had the kill switch give them trouble, bike stored outside etc., but on the MK-1 and MK-2, the MK-3 has seen some major changes to covering the electrics and protection from water of these.
Is that why it's recommended in the manual to turn the bike off with the key rather than the kill switch?
So as not to wear the kill switch out and to prevent issues like these?
post #15 of 18 (permalink) Old 09-03-2017, 07:30 AM
Good logic, which is what it takes to analyze electrical issues. You must think like a electron! When I have issues like this, I often have to step back, take a breath, and thing through the problem, often talking to my self in the process! That usually straightens it out for me. (My neighbors look at me kind of weird though).
BEST,
ANDY
post #16 of 18 (permalink) Old 09-04-2017, 02:22 PM
NO - it's so you don't forget to turn the ignition key to OFF, draining the battery IF it's left ON. Here's a video that I just got today which debunks the issue, from MOTORCYCLIST magazine:
MC Garage Video: Debunking the Motorcycle Kill-Switch Mystery
https://mg.mail.yahoo.com/d/folders/...a1u4g7FQFFDNbA
post #17 of 18 (permalink) Old 09-05-2017, 10:14 PM
NightRider's Avatar
Well there's no chance of that happening, since I need to lock the steering and take the key with me.
My reason for using the kill switch was always one of concern actually, in case somebody somehow managed to the bypass the lock or get a hold of my key I always hope they'd forget the kill switch and give up (because that actually happens to us too).
I was actually thinking of adding a second kill switch somewhere under the front fairing for security purpose, hidden but accessible by hand so I'm the only one who knows about it.
quexpress likes this.
post #18 of 18 (permalink) Old 09-06-2017, 10:59 AM
Well there's no chance of that happening, since I need to lock the steering and take the key with me. ....
I ALWAYS hold the clutch lever IN, bike in gear, then put my sidestand DOWN, thus shutting OFF the engine. Then I lock the steering (way LESS damage IF it falls over).
NightRider likes this.
